Thread: Why Doesn't my MFD show tank range?
Results 1 to 10 of 10
  1. Why Doesn't my MFD show tank range?
    I have a 2003 GT TDI 130, and for some reason the Multi Function Display doesn't show the remaining estimated mileage in the tank. I wasn't aware that it was supposed to show this until recently when I was waiting for the OH to come out of a shop, and so started reading the manual. It woud appear that most other people do have this option. I know it's not totally reliable, but it's going to annoy me if I don't find out why it's not in my display.
    I have access to VAG-COM if it's something that can be adjusted in there... though would appreciate a pointer on 'how-to'
  2. Re: Why Doesn't my MFD show tank range?
    Bath, Somerset
    I think the Golf Anniversary had this and maybe the R32 and Bora, but I think it's because these models used the Bora instrument dials. All the Mk4 golfs we have had in our family have never had the "miles to empty" screen in the computer.....
  3. Re: Why Doesn't my MFD show tank range?
    depends on the cluster you've got fitted, some simply need the eeprom editing to enable it. if you're unlucky, you'll need to retro fit a later cluster.
  4. Re: Why Doesn't my MFD show tank range?
    Quote Originally Posted by Eshrules-Enterprises View Post
    Thanks. Sorry for the ignorance, but what's eeprom?
  5. Re: Why Doesn't my MFD show tank range?
    Sep 2007
    Essex boy in Suffolk
    The eeprom (electronic erasable programable read only memory) is the chip in your cluster.
    IIRC your cluster needs to be an imobiliser 3 type, you need a VAG Tacho cable and software.
    Google it, theres loads on the net.
    I did it on my 2002 1.8T Bora but couldn't do it to my mates 2002 v5 Golf.
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  6. Re: Why Doesn't my MFD show tank range?
    Bath, Somerset
    I am quite interested in doing this to my 2003 Golf as I find it useful on our Audi A3. If you get the "miles to empty" function set up would I lose any of the programs I already have with the computer or does it just add it on??
  7. Re: Why Doesn't my MFD show tank range?
    Aug 2006
    I have a Mk4 Golf Tdi 150 2003 plate and my one does not show the range - which i find annoying - can you use something like VAG come to edit it or is there an easier way
  8. Re: Why Doesn't my MFD show tank range?
    May 2008
    You need VAG-TACHO as stated above to reflash the EEPROM in the cluster.
  9. Re: Why Doesn't my MFD show tank range?
    Quote Originally Posted by Issac Hunt View Post
    Again, cheers... I can borrow a VAGCOM cable from a mate. Someone else has asked in this thread - will reflashing the ROM chip wipe everything else?
  10. Re: Why Doesn't my MFD show tank range?
    May 2008
    VAG-COM and VAG-TACHO arent the same product, You cant run the VAG-TACHO program with a VAG-COM cable.
  1. key fob range
    By kmj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-06-2008, 03:14 PM
  2. TDi fuel tank range
    By Deviousdavey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-03-2008, 03:03 AM
  3. GTTDI 130 Tank range
    By BSB in forum Golf MK4 - 1999 - 2004
    Last Post: 30-10-2007, 11:07 AM
  4. The Commercial Range
    By RickT in forum The Commercial Range
    Last Post: 06-04-2007, 01:41 AM
  5. Edition Show & Shine Show
    By stuart in forum Shows & Events
    Last Post: 18-07-2004, 03:51 PM
