Thread: 01134 - Alarm Horn (H12) Fault Help please
Results 1 to 10 of 14
  1. 01134 - Alarm Horn (H12) Fault Help please
    Hi guys, i got this result from a recent scan and i was hoping someone might point me in the right direction as to finding the actual fault - the car is an 2004 Audi A6 1.9Tdi Avant. I have cleared the fault a few times but it always comes back
    All advice appreciated.
    Many thanks
    Midge.
    Address 35: Centr. Locks
    Controller: 4B0 962 258 N
    Component: Zentralverrieg.,DWA D38
    Coding: 06859
    Shop #: WSC 00097
    1 Fault Found:
    76-10 - Terminal 30 missing - Intermittent
  2. Re: 01134 - Alarm Horn (H12) Fault Help please
    Southern County Softy
    20 Post(s)
    Does the alarm sound when you set it off ?
    A4 2.5 tdi QS (mapped)
  3. Re: 01134 - Alarm Horn (H12) Fault Help please
    Quote Originally Posted by kite View Post
    Hi Kite - that was a quick reply thanks.
    I have just tested it (Sitting inside while armed) and the alarm activated after i moved. The indicators started flashing and there was an audible sound from the rear of the car similar to what you might hear when lorries are reversing - there was nothing really loud or anything that sounded like an ordinary car horn. To be honest, i don't know what the alarm should sound like - i know, bit daft really...
    Any ideas?
    Many thanks
    Midge.
  4. Re: 01134 - Alarm Horn (H12) Fault Help please
    20 Post(s)
    Well your alarm works...........
    Can't find that fault code on the Rosstech wiki.
  5. Re: 01134 - Alarm Horn (H12) Fault Help please
    Kite -
    Sorry just remembered, a couple weeks ago the alarm went off and the indicators flashed but there was no sound – I guess this might be the intermittent fault?
    Midge
  6. Re: 01134 - Alarm Horn (H12) Fault Help please
    20 Post(s)
    Try scanning again and clearing the codes.
  7. Re: 01134 - Alarm Horn (H12) Fault Help please
    Just done that and it is now clear, trouble is, i have done this before and it always comes back? A loose connection perhaps?
    Many thanks
    Midge.
  8. Re: 01134 - Alarm Horn (H12) Fault Help please
    20 Post(s)
    Could be a loose connection somewhere !
    Bloody intermittent faults
  9. Re: 01134 - Alarm Horn (H12) Fault Help please
    Too right! Nothing worse to take to a garage. Ah well, maybe some kind soul on this forum might be able to help.
    Thanks anyway,
    Midge.
  10. Re: 01134 - Alarm Horn (H12) Fault Help please
    Ambler, PA, USA
    Quote Originally Posted by midge6 View Post
    Thanks anyway,
    Midge.
    I agree - you have a connection issue and short of chasing the wiring to the alarm, I see no way to resolve it. A good starting place would be to trace and check all connectors related to the horn. It will not be fun! Intermittents never are! (Could be a loose pin, a bad crimp on a wire, corrosion in a connector .....)
  1. change alarm horn ???
    By alan1812 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-08-2008, 02:19 PM
  2. Alarm Horn ????
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2008, 06:44 PM
  3. Golf Alarm Horn
    By Bushy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-04-2007, 11:41 PM
  4. alarm battery/horn
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 04-04-2007, 09:57 PM
  5. Sharan alarm Siren or Horn?
    By chispa111974 in forum Touran - Sharan - Caravelle
    Last Post: 18-03-2007, 10:02 PM
