Thread: AUDI A4 Wiring for Car Stereo
Results 1 to 10 of 11
  1. AUDI A4 Wiring for Car Stereo
    Nov 2008
    I'm trying to fit a panasonic head unit into my 2004 A4 but I cannot find out which wire is the Ignition Switch. Does anybody know what colour it is?
  2. Re: AUDI A4 Wiring for Car Stereo
    Jun 2008
    there isn't one. I found this out when fitting a head unit in my B6. The standard radio is switched on by a low voltage signal from the can bus.
    Options are:
    1 Connect the permanent live to the swiched live. Result means radio on all the time and flat batteries unless you remember to switch it off.
    2 Spend around £20 on a 'can bus module' that will switch on and provide power when ignition key is inserted.
    3 Tap into a fuse which is live when iginition on.
    4 Or wire in a relay which is switched from the ignition loom (needs some, but not lots, of knowledge of auto eletrics and a circuit tester)
    Also helps if you use the correct wiring harness adapator. I also found I needed an aerial amplifier to get a decent radio signal, even on FM.
    hope this helps
  3. Re: AUDI A4 Wiring for Car Stereo
    REZ Guest
    Quote Originally Posted by A4OBAN View Post
    Options are:
    hope this helps
    it really is a bloody nightmare fitting an aftermarket headunit! STILL havent got mine working fully.. do your rear speakers work as they did before with the new harness? mine are really quiet? leads me to think ive bought the wrong iso harness to power the pre-amped rear speakers..
  4. Re: AUDI A4 Wiring for Car Stereo
    Sep 2007
    Windsor
    I think there are two wiring adaptor available. One for 'BOSE' and one if you haven't.
  5. Re: AUDI A4 Wiring for Car Stereo
    Sep 2008
    London
    i just got a JVC KD-AVX44 fitted on saturday exellenct dvd head unit and look perfect in the Audi A4 04 yes you will def need a radio aeriel amplifyer and the sound should be even better through all the speakers once you've fitted a decent headunit. i have mine connected to live which just means i have to turn the headunit off instead of using the ignition, i dont think its a big problem personally, def not worth playing around with fuses etc......
    good luck
  6. Re: AUDI A4 Wiring for Car Stereo
    REZ Guest
    Quote Originally Posted by xenon View Post
    youre absolutely right, i found out today i have the wrong adaptor!! correct one winging its way to me as we speak and hopefully be in for friday.. next job, replacing passenger side speaker..
  7. Re: AUDI A4 Wiring for Car Stereo
    Dec 2007
    I have an 02 plate audi a4 b6 and ive replaced the head unit for an aftermarket model and have found that the radio reception is really poor.
    i have used an aerial adapter (pc5-90) to supply a 12v feed to it as i needed to do on almost all of my other cars, but still the radio reception is very poor.
    I noticed on removal that there is a yellow plug (pictured) that fits into the back of the old head unit (a concert cd unit) which i havent used in the new one as there is no space for it, does anyone know what this wire is and what relevance (if any) it has to the poor reception.
  8. Re: AUDI A4 Wiring for Car Stereo
    Options are:
    hope this helps
    any idea where i can get one of these modules ? or any way of making some thing that feeds off the permenant live thats non active untill the can wire wire power switches it to connect the permanent live
    or is the item at the bottom any good ? http://www.nexxia.co.uk/Car_Stereo_fitting_kits.htm
  9. Re: AUDI A4 Wiring for Car Stereo
    Aug 2008
    Warwickshire
    I believe the yellow wire is to do with the speed sensitive volume adjustment on the Concert cd head unit.
  10. Re: AUDI A4 Wiring for Car Stereo
    Nov 2008
    Beds
    Does anyone know what the power of the amplifier is in a 2004 A4 Avant? Its got a small sub in the side of the boot and i want to upgrade it if possible.
    Is it possible to:
    Wire a slightly bigger sub (depending on size of the Audi Amp) instead of the Audi sub?
    Or
    Remove the wiring from the Audi Amp, install a new bigger amp and then a bigger sub?
    I want to keep the standard head unit if possible which i didnt think was going to be possible until i saw it already has a small sub from factory.
    Ta.
  1. stereo wiring
    By taztaz in forum Bora - 1998 - 2005
    Last Post: 28-04-2008, 08:25 AM
  2. Stereo don't work, but think its the wiring
    By macca73 in forum Touran - Sharan - Caravelle
    Last Post: 19-04-2008, 09:30 AM
  3. stereo wiring harness
    By otis_b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2007, 02:20 PM
  4. audi a4 1997 stereo wiring help
    By brettcurran in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2007, 10:10 PM
  5. 80 sport stereo wiring
    By Ian W in forum 80 - 90
    Last Post: 18-04-2007, 04:08 PM
