Thread: abs control module incorrectly coded 01044
  1. abs control module incorrectly coded 01044
    Jul 2008
    hi all need a bit of help, i have vag com shareware version when i scanned my a4 2.5 v6 tdi 2004, fault code 01044 control module incorrectly coded. the code is set to 0000, when i tryed to enter the correct code in using the login code first then the soft code it accepted them but would not hold the code when you clicked off the abs screen and returned the codes disappeared. the abs light and esp light are always on. is there a way of storing the codes forever. and will i have to upgrade my vag com to the full version to do this thanks all.
  2. Re: abs control module incorrectly coded 01044
    london/ UK
    Quote Originally Posted by cob View Post
    I believe that ur version of software should be fully activated to erase faults from ABS controller. At some point, someone replaced the pump you have on the car with a second hand pump and it was not programed properly...The pumps electronics are known to fail internaly- dry joints most of the time.
  3. Re: abs control module incorrectly coded 01044
    Jul 2008
    i forgot to mention i think it was me who erased the abs module code, when i erased a fault.
  4. Re: abs control module incorrectly coded 01044
    Magdeburg, Germany
    The login/coding procedures needs to be followed by the appropriate and successful basic setting, which means the shareware version will be of no help here. I suggest you take it to the dealer then...
    Sebastian @ www.Ross-Tech.com
  5. Re: abs control module incorrectly coded 01044
    Jul 2008
    so do you think if i get the full version of vag com i could recode the module.
  1. Where is my Comfort Control Module (CCM)
    By Digidick in forum Toledo
    Last Post: 24-10-2008, 06:22 AM
  2. fan control module
    By chris954 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2008, 05:43 PM
  3. Transmission Control Module
    By Crockett in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 08:33 PM
  4. Transmission control module
    By recruiter111 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2008, 01:35 PM
  5. discomfort control module
    By southwest in forum Passat - Archive Topics
    Last Post: 27-04-2007, 03:25 PM
