Thread: .19tdi vrs 1.9tdi pd
  1. .19tdi vrs 1.9tdi pd
    HI new to the forum.
    what is the difference between the 1.9tdi and the 1.9tdi pd engines in the octavia. also did the model change in 2005. thanks for any help
  2. Re: .19tdi vrs 1.9tdi pd
    Chester-le-Street, United Kingdom
    tdi engines have a "conventional" injector pump feeding the injectors.
    the pd engines have "individual injector units/pumps,the injection being operated by the camshaft,and the amount of fuel by injector solenoids on each individual unit.
    no idea about model changes though.
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: .19tdi vrs 1.9tdi pd
    Nottingham
    The octavia 1 is based on the golf 4. The octavia 2 (2005 on) is based on the golf 5 and a totally different car. Both are good and a little different.
    Without going into the technical nuts and bolts, the pd in the octavia 1 was 130hp, vs the tdi's 90 and 110hp (SLX, L&K and Elegance were 110hp, 130pd option later on Ele/L&K only if I remember).
    The pre-pd tdi is more durable engine wise, less heads and turbos go. BUT, more minor faults/sensors/maf etc. The PD uses more fuel but has more power. The tdi uses less fuel, even when you compare say a pd100 to a tdi110 the tdi can be up to 10mpg better.
    If you drive little or don't care about mpg and have a big budget go for a pd130, with the 6 speed box a very swift motor.
    Otherwise go for the very competent & more econmic 110tdi.
    Greg.
  1. 19TDI 110 1997 power loss !!!!!!!!!!
    By nobbie1010 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2008, 03:05 PM
  2. Just got 54reg 19tdi 100
    By Cosmick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-12-2007, 01:22 AM
  3. sharan 19tdi gearchange info
    By graemeb in forum Touran - Sharan - Caravelle
    Last Post: 29-11-2006, 10:47 PM
  4. sharan 19tdi transmission
    Last Post: 29-11-2006, 10:34 PM
