Thread: MK 5 1.6 FSI engine stuttering/miss-fire
  1. Angry MK 5 1.6 FSI engine stuttering/miss-fire
    Jun 2008
    There appears to be a common problem with the 1.6 04 Golf FSI where the engine sometimes stutters/splutters usually at motorway speeds or navigating roundabouts. When the engine is turned off for a couple of minutes and then restarted the problem disappears for while.
    The problem can be very infrequent but in some situations very dangerous since when it occurs the car looses all acceleration capabilities and struggles to achieve high revs even in a lower gear.
    Im sure there must be someone on here that could solve this problem once and for all and I would be very grateful of any advice.
    Thanks in advance.
  2. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    gsmmad Guest
    get your car diagnosed, it could be your coil pack. I had a silimar problem, my car would shake for no reason and then when im pressing down on the pedal it would not gain the power properly. RAC came down and told me it was the coil pack.
    However i did get the engine light straight away and it was flashing.
  3. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    Dec 2008
    Croydon -Surrey
    Im having this same problem......is there a solution?!
    Ive had so many different answers...
    1 - Battery
    2 - MAF Sensor
    3 - Coil Pack
    4 - Fuel Pump
  4. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    Dec 2008
    Iv just had this fixed on my 98 1.6 audi a3, dirty throttle body from un metered air leak.
    FIX: Throttle body cleaned and readapted ,new air induction pipe..£80 all in. this will b cheaper for ur golf
    I also replaced coil as luckily??..it FINALLY and suddenly went on me(u will def know when this happens!!!) but used to cause intermittant rpm loss/ no start/lack of power/ eventual misery.. £83. vw replacement.
  5. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    Jan 2009
    HI ALL IAM HAVING THE PROBLEM OF LACK OF POWER AND REVS DYING ON MY 2.0 GT FSI WHEN IN MOTION SOMETIMES WITH PEOPLE NEARLY SHUNTING ME ,TAKEN TO VW DEALER DONT HAVE A BLOODY CLUE CHANGED FUEL FILTER ,YET PROB STILL HAUNTS ME ANY BRIGHT IDEAS ANYONE PLEASE
  6. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    Dec 2008
    ********************** I AM NO EXPERT .************************
    im pretty sure power loss issue is coil pack failiure. BUT before splashing out. Read about "dry joints" in fuel pump/ecu relays located elswhere on these forums.(perticually audi 80/100) if u know what your lookin 4 u could fix this 1 4 pence.
    NEXT. check air induction pipe 4 leaks. unmetered air gettin in engine will limit performace as much as a bad Mass airflow meter. the MAF sensor can b cleaned but read "how 2" before u try.
    Duff Coolant temp sensors cause many runnin issues..cheap 2 replace
    Get your throttle body checked out on vagcom. if the servo motor in it is playing up it will adopt a mind of its own and confuse any good garage. these r not cheap 2 replace .
    coil pack is prime suspect i replaced mine myself and i have no power loss issues any more
  7. Re: MK 5 1.6 FSI engine stuttering/miss-fire
    Mar 2012
    romania
    how did you fix this problem?
  1. Question engine miss fire/splutter
    By Chris1098 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2008, 08:07 AM
  2. A3 2.0 Tdi miss fire on tick over
    By Bongo163 in forum Audi A3 - Archive Topics
    Last Post: 06-06-2008, 01:56 PM
  3. Please Help miss fire at 3000rpm
    By ian b in forum Golf MK3 - 1993 - 1999
    Last Post: 26-05-2008, 12:22 PM
  4. miss fire on s4
    By biglad123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 03:09 PM
  5. problem with miss fire on bora
    By vwbora16valve in forum Bora - 1998 - 2005
    Last Post: 29-12-2006, 12:23 AM
