Thread: Red Brake warning light flashes on the Driver info screen
Results 1 to 10 of 15
  1. Red Brake warning light flashes on the Driver info screen
    Mar 2007
    Hi, I have just purchased an 04/04 A4 Avant 1.9 tdi 130 and its great ! However, the red brake warning light has started to come on, but no descriptive message as to the fault, when you first start the car and then it goes out. It is not consistent either, only coming on some times. It has just had a service by Audi. I think it may just be a fault with the brake warning system itself but not really sure so any help would be really appreciated.
  2. Re: Red Brake warning light flashes on the Driver info screen
    Aug 2007
    Hi Ben,
    You're best getting a fault code scan done, particularly when it comes to brakes.
  3. Re: Red Brake warning light flashes on the Driver info screen
    I too have this quirk on my car (04/04 avant 1.9tdi 130) Does the car turn over and fire up fine as mine struggles sometimes (often liinked with the brake warning)? If the warning dissapears after the three beeps or so, it should not be a serious prob - just a little irritating. This could be due to a drop in volatge from the battery on turnover or possibily pressure not up quite as quickly enough...)Hopefully someone who actually knows about this might be able to comment further!) Importantly if it remains on stop! I will keep you posted if I find out more - already had a crank sensor, air sensor and a non-return valve replaced, but no luck yet!
  4. Re: Red Brake warning light flashes on the Driver info screen
    As for fault codes - Mine gave no fault codes for this?
  5. Re: Red Brake warning light flashes on the Driver info screen
    Mar 2007
    Thanks for the info - My Dad mentioned that the hyrolic PAS fluid might be low as this is linked to the brake system - as yet have not had a chance to check but worth ticking off the list ! I will let you know the outcome ............
  6. Re: Red Brake warning light flashes on the Driver info screen
    Mar 2007
    Seem to have sorted this by topping up the brake fluid !
  7. Re: Red Brake warning light flashes on the Driver info screen
    Dec 2006
    Quote Originally Posted by Ben33 View Post
    I would of said the front pads are low and the sensor is just making contact.... OR the sensor on the front pads is has a lose connection hence tripping the light on
    Check the level of the front pads...
    Rick
  8. Re: Red Brake warning light flashes on the Driver info screen
    Mar 2007
    Lancashire
    tut tut
    At least it seems sorted.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  9. Re: Red Brake warning light flashes on the Driver info screen
    Mar 2007
    Front pads are fine - I believe it would be an amber warning symbol if the pads were low .....
  10. Re: Red Brake warning light flashes on the Driver info screen
    Dec 2007
    it is a constant amber light for front pads
  1. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  2. Please Help Sharan TDI Glow plugs warning light flashes on and off briefly...
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 22-05-2008, 07:00 PM
  3. Oil Warning Light Flashes
    By T8LTS in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-07-2007, 04:11 AM
  4. Break Warning Light on Dashoard Flashes
    By Durness in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-07-2007, 10:53 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
