Thread: Bonnet wont close
Results 1 to 8 of 8
  1. Bonnet wont close
    Need help my bonnet wont close completly, it catches so it doesnt fly up but it will not lock closed. Any advice thanks
  2. Re: Bonnet wont close
    Hi I would say the locking devise needs adjusting.
  3. Re: Bonnet wont close
    Do you know how to adjust the lock, Thanks
  4. Re: Bonnet wont close
    Hi You need first to see if the locking devise is working,get someone to pull the lever which opens the bonnet,check if the locking devise opens and returns as you pull and release the lever.
  5. Re: Bonnet wont close
    Apr 2007
    Lancashire
    Try lubricating the mechanism first, as it can become very stiff and stop closing properly.
  6. Re: Bonnet wont close
    Aug 2006
    Sometimes you need to ensure that the handle is back on its stops. Indication that lubrication is needed somewhere
  7. Re: Bonnet wont close
    Sep 2008
    Birmingham
    Quote Originally Posted by ini View Post
    The mechanism in the slam panel often sticks, clean the lock out and lube with some freeing oil (ie. WD40) and see if it improves matters. If you can get it working give it a nice smearing of grease to keep it moving.
  8. Re: Bonnet wont close
    Thanks for all the advice will give the lock a good clean and grease the lock hope its sorts out the problem.
  1. T4 wont start unless I close the relay?
    By vma99r in forum The Commercial Range
    Last Post: 14-02-2009, 06:51 PM
  2. Please Help electric window wont close properly
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2008, 09:03 AM
  3. How do YOU close your bonnet?
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-05-2008, 09:30 AM
  4. So close, but yet so far :-(
    By bora(ing) nick in forum Chat - Anything with wheels
    Last Post: 26-01-2008, 11:16 PM
  5. W Reg Passat - Bonnet Release (at front of bonnet)
    By AndyD in forum Passat - Archive Topics
    Last Post: 01-01-2007, 06:09 PM
