Thread: S3 audio wiring
Results 1 to 10 of 16
  1. S3 audio wiring
    Jul 2008
    Poole
    anyone know where i can get diagram of the wiring layout for the audio system in a v reg S3?
    cheers guys.
    Proper Metal, Played The Proper Way!!
  2. Re: S3 audio wiring
    Dec 2007
    Bedford
    Quote Originally Posted by Mr_Tony View Post
    cheers guys.
    Hi Mr_Tony,
    Are you just looking for the wiring that goes into the head unit end or for the audio loom for the whole audio system?
    I am pretty sure that the head unit end is just a standard ISO connection.
  3. Re: S3 audio wiring
    Jul 2008
    Poole
    Ideally the whole loom. The car has a kenwood head unit in it, and all sorts of weird wiring ive never seen before.
    Seems to have some kind of crossover which the speakers are all wired too, which im guessing is to do with the sub??!
    Just be good to see how the amp is wired up etc, etc.
    Any ideas??
  4. Re: S3 audio wiring
    Dec 2007
    Bedford
    Any ideas??
    The crossovers would have been installed if you have comp speakers installed (mids & tweeters seperate).
    I'm afraid that I have have a copy of the whole wiring loom only for standard ISO connections... Try like the A3 side of the forum?
  5. Re: S3 audio wiring
    Jul 2008
    Poole
    I thought this too, but it only has one crossover which is tucked behind the headunit. Weird!!! All the connectors are ISO. The speaker outs plug into this crossover thing, which plug into the Audi connectors. Going to investigate it further 2moro. If i could get a copy the ISO wiring loom, that would be awesome, cheers.
  6. Re: S3 audio wiring
    Dec 2007
    Bedford
    LOL That does seem wierd... Must have been installed by Mickey Mouse! lol
    I will try and find you a copy of the ISO wiring diagram and I'll post it on here
  7. Re: S3 audio wiring
    Jul 2008
    Poole
    Haha. Thanks alot bud.
  8. Re: S3 audio wiring
    Dec 2007
    Bedford
    As you know the ISO connection has 2 "blocks"
    One is for the power and the other one is for the speakers
    If you look at the ISO connector as shown in the diagram and then use the key
    POWER CONNECTOR
    1 = Tel Mute (if attaching a handfree kit -> it will mute the head unit when you get an incomming call)
    4 = +12V (power always running throught this cable - used for the "memory" of the head unit)
    5 = Auto Antenna - IMPORTANT: on ALL VAG cars you can use this cable if linking to a antenna amplifier... All VAG OEM head units have a built in amplifier to boost the radio signal so if you want to use the radio you have to buy a booster and connect it to this cable (DO NOT ATTACH TO AMP REMOTE OUT)
    6 = Illumination (will auto dim the head unit with you swith your lights on
    7 = Switched +12V (power only runs when the ignition is switched on - used to power head unit)
    8 = -0 Earth (Ground)
    ***Note that when wires 4 & 7 go into the Kenwood head unit these wires may be switched as most German cars have these cabled in each others positions on the wiring loom***
    SPEAKER CONNECTOR
    1 = + Rear Right
    2 = - Rear Right
    3 = + Front Right
    4 = - Front Right
    5 = + Front Left
    6 = - Front Left
    7 = + Rear Left
    8 = - Rear Left
    I hope that I have not just blabbed on and that it helps!
  9. Re: S3 audio wiring
    Jul 2008
    Poole
    cheers mate
  10. Re: S3 audio wiring
    Dec 2007
    Bedford
    I have just updated it!
  1. a8 audio,av1 av2
    By hacket har in forum A8 - S8 - V8
    Last Post: 27-08-2008, 10:41 PM
  2. a3 audio modifications
    By richard.ev in forum Audi A3 - Archive Topics
    Last Post: 30-11-2007, 08:16 PM
  3. Passat Audio Wiring - Random Wire
    By Eckie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2007, 02:47 PM
  4. Audio MP3
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-11-2007, 02:30 PM
  5. Vw audio
    By Andy N.I in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2007, 12:13 AM
