Thread: 4 beeps heard from the rear ?
Results 1 to 10 of 12
  1. 4 beeps heard from the rear ?
    safehands Guest
    ok , this is strange !! had my a4, 4 months now , now when you start up in the morning im hearing 4 beeps from the rear of the car ? boot area ?
    its not got rear parking sensors so its not that !! any ideas ?
    just started happening , ive put a new battery on last week , would this have anything to do with it ?
    help !! gav .
  2. Re: 4 beeps heard from the rear ?
    May 2008
    It will be from the battery back up alarm module. Its an indication that the battery in the alarm module is wearing/worn out.
    Replace the entire module is the offical Audi method to fix it. However I would be opening it and buying a replacment battery from Maplins!!
  3. Re: 4 beeps heard from the rear ?
    safehands Guest
    Quote Originally Posted by Issac Hunt View Post
    ah ok thanks, where abouts in the car is it ? the noise sounds like its
    coming from the boot area ? does that make sense !!
  4. Re: 4 beeps heard from the rear ?
    May 2008
    Yes the alarm back up sounder is in the boot behind the trim panels, i think its on the left hand side.
  5. Re: 4 beeps heard from the rear ?
    Tiptree, Essex
    Looking into the boot from the rear it's on the other left side, i.e. Right side!
    Have this procedure I wrote on file and posted in the "How To" section for reference..........
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=49828
    Last edited by Woorlord; 05-10-2008 at 11:32 AM. Reason: inserted Link to "How To" section
    A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
  6. Re: 4 beeps heard from the rear ?
    safehands Guest
    thanks woorlord , issac hunt , on the case now .
    thanks again .
  7. Re: 4 beeps heard from the rear ?
    safehands Guest
    ok update on this, what does the alarm siren sound like ? i activated
    my alarm today and the siren was pretty poor and coming from the boot area , was this from the module ?
    is the alarm not horn based , sounding ? new to audi and not heard the alarm going off yet !! so set it off today to try it and seemed very quiet !!
    help !! ps had a new battery fitted to the car last week , could this be linked ? thanks again ..gav
  8. Re: 4 beeps heard from the rear ?
    Tiptree, Essex
    Quote Originally Posted by safehands View Post
    Not horn based - solid state intelligent sounder type siren unit.
    Like a very very loud digital alarm clock....... BEEP.....BEEP.....BEEP.....BEEP......etc. for ~30seconds and then it resets.
    Your internal siren batteries are knackered and this can affect the unit in various ways. By removing the duff internal batteries this will make it work again more reliably but with no battery backup. I ran mine like this for a while (12 months) before I got around to sorting it out with the indicated mod.
    Batteries don't last forever - however the technology is getting better. The fact that your main battery required replacement meant that at start-up of your engine it was struggling to provide the current which in turn resulted in the siren unit noticing a momentary loss of supply or below it's trigger threshold - hence the strange beeps from the boot at start-up.
    How the siren works.....
    The alarm uses three wires - 0v, 12v and communication wire.
    The communication wire is not like conventionally non-intelligent battery backed sirens where you trigger the siren on the 3rd wire with simple voltage level. If this was the case, by removing all 3 wires the siren would sound with the internal batteries! I believe the siren is signaled by the convenience module on the state of the internal alarm - i.e. Alarm On or Alarm Off. If the car battery is removed whilst the Alarm is On - then the siren has the intelligence to sound the siren beep beep beep for 30 secs. recycle, check car supply and resound another 30 secs. indefinitely. If the convenience module senses an intrusion it will tell the siren to sound. However, if you remove the car battery whilst the Alarm is Off, it will not sound. Old systems (VW Passat ~ Yr 1998- had an override key to be used if battery supply was removed.)
    If the internal batteries fail, you may get strange beeping noises from rear of car at engine start. You may get other unexplained false alarms etc.. VAG-COM should identify if the alarm system has been triggered by an external sensor.
  9. Re: 4 beeps heard from the rear ?
    The alarm volume on my A6 is very low too, i thought that the previous owner might have had it set it that way if he lived in a built up area but aparantly they are all very quiet.
    From reading other posts i dont think this can be adjusted either.
  10. Re: 4 beeps heard from the rear ?
    safehands Guest
    Quote Originally Posted by Woorlord View Post
    thanks woorlord gonna get it sorted at work , pwerhaps the battery mod , like on the tt owners site !! dont really want to pay audi £86 for new unit !!
  1. About to buy A3 TDi 140, help needed with noise heard on test drive.
    By firewalker in forum Audi A3 - Archive Topics
    Last Post: 23-09-2008, 05:13 PM
  2. Funny stories that you've heard
    By cpiddy7 in forum Chat - Completely Off Topic
    Last Post: 07-03-2008, 09:52 PM
  3. Any one heard of...........
    By gav_j_crompton in forum Chat - Anything with wheels
    Last Post: 01-02-2008, 12:58 PM
  4. Can this be True - Re Programming-Has anyone heard of this
    By Ver09 in forum Passat - Archive Topics
    Last Post: 19-01-2008, 11:25 PM
  5. anyone heard of???
    By passatmick in forum Chat - Anything with wheels
    Last Post: 28-11-2007, 07:21 PM
