Thread: T4 horn problem
  1. T4 horn problem
    Aug 2008
    Hi there, I have just replaced the standard horn on my 1998 transporter T4. I bought a Nautilus 12v twin air horn from ebay. I simply replaced existing horn and it worked perfectly ( for 2 weeks). Used it today and nothing happened. I have checked all fuses and are all ok. Horn was supplied with a relay but I didn't fit it as I wasn't sure where to fit it and horn worked 1st time, I took off steering wheel horn plate and got a spark from wires when touched but no horn sound. I also refitted original horn and still no horn, checked horn on battery and it worked fine.
    My questions are
    1,Which fuse is for horn and what size should it be?
    2, Which relay is for horn?
    3, Should I have fitted relay or does van already have one?
    4, How can I check wiring with multimeter?
    Thanks in advance
    Gary
  2. Re: T4 horn problem
    i had this problem, i installed a horn, it worked fine and then it died. it turned out to be coroded wires near the horn. try and trim back the wire so its clean and re connect the horn.
    hope it helps.
  3. Re: T4 horn problem
    Margate,Kent
    Quote Originally Posted by GO1965 View Post
    In a word - yes.
    When you have sorted the problem be sure to fit the relay !
    take care & enjoy life
    Brian Considine
  1. 2001 A6 Avant Horn and central locking problem
    By henlowstu in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-07-2008, 12:45 AM
  2. Horn problem
    By davec573 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-06-2008, 12:09 AM
  3. Horn on my 97 A6
    By luvmyaudi in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-02-2008, 11:32 PM
  4. Horn
    By greaseball in forum Altea
    Last Post: 19-10-2007, 07:47 PM
  5. airbag & horn problem
    By Kat2006 in forum Archive posts
    Last Post: 03-08-2006, 01:21 PM
