Thread: VW Passat Headlight Converter switch
  1. Question VW Passat Headlight Converter switch
    Aug 2005
    I have a RHD Volkwagen Passat first registered in 2002. I will be travelling in Europe shortly and need to adjust my headlights so as not to dazzle oncoming drivers. Can anyone point me to instructions for carrying out this procedure?
    Feb 2004
    Yorkshire
    49 Post(s)
    Thanks for joing and posting on the site
    This question has been asked before, and can be done please see the following thread:
    https://www.vwaudiforum.co.uk/forum/showthread.php?t=449
    Hope this helps
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  3. VW Passat headlamp level worn
    Jun 2006
    Hi, I have a VW Passat R reg. MOT failed because headlamp are pointing low. Can not adjust because the leveler is worn out and have been quoted £300 for fitting new headlamps. Does any one have experienced this problem and is there a cheaper way to adjust?
    Sensible-Lord Guest
    Shanda, I had the same problem on a 2001 estate. The plastic adjuster had broken, it failed the MoT on this and VW wanted about a million quid to replace the whole light unit. Not only is this wasteful and expenstive it means they don't get my business. A trusted local garage did a bit of head scratching and removed the plastic hex head to reveal the threaded rod. A quick saw-cut on the end and you have the facility to adjust the light again (90˚ flat blade) and get an MoT. This garage shall have my business again.
  5. Smile
    Jul 2006
    Firstly - hello fellow passat owners!!
    Quote Originally Posted by ianadie
    I also have a RHD Passat (2003) TDI sport with xenon headlights - I have looked through the main post on this forum but it does not seem to tally with my headlight units.
    My lights are arranged thus; from car centre line to outside - side light (bulb type), indicator (bulb), main headlight (xenon)
    The nearside (LHS) unit is easier to access, once you have removed the oil resevoir shroud, and the back plate of the light unit - which only seems to give access to the indicator bulb and the sidelight.
    There are two 'adjusters' - machine screw type heads that lie in a vertical orientation. turning these with a 6mm allen key causes a worm wheel to rotate - I assume these two are for alignment of the main beam. One lies 75mm (approx) lower than the other at the rear of the unit (See pic 1).
    There is also a rubber bung/plug that is inserted into the side wall of the housing. Removing this reveals a orange translucent plastic machine screw head type adjuster??
    I cannot seem to locate any kind of metal tab to move up/down as described here;
    Does my situation make any sense to anyone?? Anyone know what the above mentioned orange adjuster does?? I did not want to mess with anything until I knew what I was doing !! (been bitten before)
    Any help/advice greatly appreciated - esp as we set off for france on sunday (16th!!)
    thanks
    diddy kiddy
  1. Phaeton Headlight Converter
    By Clive Russell in forum Phaeton
    Last Post: 05-04-2012, 03:10 PM
  2. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
  3. 94' Passat 1.9 TD - Dodgy Ignition Switch
    By paularcher in forum Passat - Archive Topics
    Last Post: 31-12-2006, 06:25 PM
  4. About the Catalytic Converter of Passat 2001
    By wolfterran in forum Archive posts
    Last Post: 19-10-2006, 07:46 PM
  5. Passat Headlight Bulb change
    By sp900 in forum Passat - Archive Topics
    Last Post: 10-10-2006, 03:09 PM
