Thread: golf tdi BKC engine
Results 1 to 9 of 9
  1. golf tdi BKC engine
    Sep 2008
    leicester
    hi all... can anyone help... my mate asked me to take a look at a golf tdi (new shape) 55 reg bkc engine, he's had the engine out to fit a new turbo & crank regrind as it drank all its oil & seized the crank. anyway its all back together but won't start. its spins over, theres fuel coming up to the pump on the back of the head. it starts on easy start but dies soon as you stop spraying. i've scanned it & it came up with 2 faults saying camshaft sensor power supply, we checked the power supply to the cam sensor & there is no power. trouble is my autodata cd doesn't show wiring diagram for this model so we can't trace where its supply comes from. anyone have a wiring diagram for the engine management on this engine please ?? also would the cam sensor stop it starting ?? if i had a diagram i could trace to see if this power suplly also supplies some other critical sensor which is causing non start. thanks shaun
  2. Re: golf tdi BKC engine
    Sep 2008
    leicester
    update... its giving out code 16725 which is cam sensor... we've double checked the valve timing/sensor trigger position etc.it looks like cam sensor only avalible from dealers so need to be sure. a kind guy has emailed a wiring diagram which shows all 3 wires from the cam sensor go to the ecu ? the earlier type have a fused feed. we need to know what readings we should have on each wire... pins 3 is earthed but the other 2 appear to be dead...not tried whilst cranking. anyone help please ?? shaun
  3. Re: golf tdi BKC engine
    129 Post(s)
    1972 Post(s)
    How did you set the timing, did you use the crank locking tool and cam locking pin?
  4. Re: golf tdi BKC engine
    Sep 2008
    leicester
    yes we did. thanks shaun
  5. Re: golf tdi BKC engine
    129 Post(s)
    1972 Post(s)
    I hope it isn’t the sensor, it means taking the top pulley off and not only does that mean removing the belt again but you will also need a special extractor to remove the pulley hub without damaging it.
    I have only had this code once on a car we had worked on and one of my lads had the timing very slightly out and every time I have been asked about this code by other garages and DIY types it has been the timing.
  6. Re: golf tdi BKC engine
    Sep 2008
    leicester
    thanks for that. we've already had the cam pulley off again & the hub which includes the timing disc just to double check everything. do you know what triggers the crank sensor ?? is it the flywheel or is there a disc on the crank ?? i've only got involved since its been back together but was wondering... if it had a disc on the crank maybe it could have been removed when the crank was re-ground then refitted in the wrong position... that would make the ecu you think the cambelt was out ? shaun
  7. Re: golf tdi BKC engine
    129 Post(s)
    1972 Post(s)
    There is a 60-2 disc on the rear of the crank.
  8. Re: golf tdi BKC engine
    Sep 2008
    leicester
    thanks crasher... is it possible to fit this in the wrong position so that the timing would be out ??? shaun
  9. Re: golf tdi BKC engine
    129 Post(s)
    1972 Post(s)
    I can’t see them removing it for grinding but the whole assembly is quite involved and very easy to get wrong without the correct assembly jig. PM me your email and I will send you the details.
  1. Please Help What engine oil does my golf need
    By uk1234 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-08-2009, 03:12 PM
  2. golf mk2 16v kr engine!
    By robinbude in forum Golf MK2 - 1984 - 1992
    Last Post: 12-02-2008, 11:12 PM
  3. Changing worn transporter TDI engine to Golf engine?
    By flyin-turd in forum The Commercial Range
    Last Post: 18-01-2008, 12:28 AM
  4. will a A4 engine fit a golf mk4?
    By topbuzz_uk in forum Archive posts
    Last Post: 06-01-2008, 01:35 AM
  5. AHF Golf engine
    By dreamworx in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 10:15 AM
