Thread: brake lights/glow plug light issue
Results 1 to 9 of 9
  1. brake lights/glow plug light issue
    Aug 2008
    sorry - this has been covered a lot on the forum but im still confused
    the rear brake light and the glow plug warning lights keep flashing and beeping - ive replaced all the bulbs and the brake lights work correctly
    if the brake light switch is faulty, surely the brake lights wont work at all?
    also, can someone give me an explanation of how to get to the brake light switch on the 99 A4 tdi?
    many thanks
  2. Re: brake lights/glow plug light issue
    Chester-le-Street, United Kingdom
    if the brake lights are working and the glow plug light is flashing, then perhaps the glow plugs and/or relay are at fault.
    you can check the glow plugs across a battery very easily.
    don't hold the dirty end though!!!
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: brake lights/glow plug light issue
    Jul 2008
    stoke on trent
    is it the bulb out warning, (orange, looks like onion with a cross through it) or brake fault warning flashing (red, exclamation mark)
    glow plug light flashing can mean engine/fuel fault
  4. Re: brake lights/glow plug light issue
    Aug 2008
    this fault seems to be intermitant - went to the car today and it simply flashed the bulb out warning - so checked all the lights again and the centre rear brake light was sticking on - so have been to GSF, fitted a new brake light switch, which has stopped the sticky centre light, but the brakelight warning and bulb out warning are now flashing, and the glow plug light is now flashing again??? aarrgghh
  5. Re: brake lights/glow plug light issue
    Aug 2008
    Finally got round to buying a VAG-COM cable and these were the results of the scan - can anyone advise what to check next? I've replace the brake pedal switch with a new one from GSF?
    VAG-COM Version: Release 409.1-US
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 038 906 018 FD
    Component: 1,9l R4 EDC 0000SG 2137
    Coding: 00002
    Shop #: WSC 06335
    1 Fault Found:
    00741 - Brake Pedal Monitoring
    27-10 - Implausible Signal - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    No fault code found.
  6. Re: brake lights/glow plug light issue
    Jul 2008
    I have the same fault with the glowplug light on my a4, you say there's been a lot of posts on here regarding this but i can't find any, any tips on searching? cheers
  7. Re: brake lights/glow plug light issue
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by mattpone View Post
    Address 01: Engine
    Coding: 00002
    Shop #: WSC 06335
    1 Fault Found:
    Readiness: N/A
    Coding: 0273004281
    Shop #: BB 24548
    If you clear the fault does it come back.
    A4 2.5 tdi QS (mapped)
  8. Re: brake lights/glow plug light issue
    20 Post(s)
    Quote Originally Posted by toshkavdub View Post
    Do your brakelights work OK ?
    Flashing glowplug light can be a fault with the brakelight switch
  9. Re: brake lights/glow plug light issue
    Jul 2008
    Yeah brake lights seem fine, passed it's mot today and it drives and runs fine, just the flashing light to sort out now, thanks for the tip though, i'm sure it's something simple
  1. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  2. glow plug and abs lights
    By jarralad68 in forum Chat - Anything with wheels
    Last Post: 19-01-2010, 01:00 PM
  3. Flashing glow plug lights - break lights ok?!
    By Jonny Chee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2008, 07:27 PM
  4. glow plug light
    By smiglyy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-12-2007, 09:49 PM
  5. glow plug light
    By smiglyy in forum Archive posts
    Last Post: 27-09-2007, 08:12 PM
