Thread: Audi A4 B6 Auto Lights
Results 1 to 10 of 15
  1. Unhappy Audi A4 B6 Auto Lights
    Leeds
    I am looking for some assistance here from you technos...
    I have an Audi A4 B6 1.9TDI Advant, I have noticed that when I go under tunnels etc. the dashboard lights dim, as a reminder to turn on your lights. I thought that it must be wired for auto lights, I have recently purchased an Auto light switch for the headlights (A proper Audi one).
    The problem is the lights come all the time, is their a code or something I need to do to make this work?
    Any help would be appreciated.
  2. Re: Audi A4 B6 Auto Lights
    May 2008
    Adding auto-lights isnt as simple as adding a new switch, you also need the light sensor so the car will know when its dark!
    When you pass through tunnels etc you are probably noticing that the speedo needles are illuminated - They are usually always illuminated - its just that you cant see they are on in daylight. This feature can be switched on/off using VAG-COM.
  3. Re: Audi A4 B6 Auto Lights
    Leeds
    Issac cheers for the reply, The instrument cluster dims when I go into a tunnel and I have what i assume is the sensor on the top of the dash board.
    I assume that as the instrument lights are going dim, that the feature is switched on?
    Thanks for taking the time out to answer.
  4. Re: Audi A4 B6 Auto Lights
    May 2008
    Ah yes you have a B6, slightly different to the B7. Yes I think as you mention they dim to remind you to turn on your headlights. Sounds like all is working as it should. Getting the car to turn the lights on for you wont be straightforward though sadly.
  5. Re: Audi A4 B6 Auto Lights
    Leeds
    Thanks, much appreciated, looks like a trawl through the internet to find a magic way to do it or maybe a new thread. Thanks for the help...
  6. Re: Audi A4 B6 Auto Lights
    May 2008
    I have seen a thread where someone has done this mod but I cant find the link at the moment. If I recall correctly he had to add the new headlight switch, sunlight sensor in the rear view mirror and a fair bit of additional wiring.
    EDIT - Try this for lots of information
  7. Smile Re: Audi A4 B6 Auto Lights
    Leeds
    Apologies for the delay in getting back, that seems perfect, I will now go away and investigate, I may substitute the autodimming mirror for another photosensor with some clever electronics.
    This will make good bedtime reading.
    Once again many thanks
  8. Re: Audi A4 B6 Auto Lights
    May 2007
    knee deep in clunge
    14 Post(s)
    you will need high line electrics control unit j519 for auto lights
    a quick way of telling what spec j519 is to remove the light switch and disconnect it,if the headlights come on then you have high line and you can retro fit the auto lights/rain sensor
  9. Re: Audi A4 B6 Auto Lights
    Mar 2008
    Just a quick note in this thread.
    The dash lights will dim in a tunnel because the cluster itself has its own photosensor. It only controls the cluster brightness- nothing else.
    Nothing to do with the Autolight sensor which controls whether headlights come on or not - that is a totally separate system.
  10. Re: Audi A4 B6 Auto Lights
    May 2007
    knee deep in clunge
    14 Post(s)
    The auto lights require highline j519 and the sensor in the mirror housing for the windscreen and the light switch
  1. Audi A6 SE Auto
    By boy1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-03-2008, 04:54 PM
  2. Audi A6 TDI Auto breakdown
    By afe410 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-03-2008, 06:51 PM
  3. Audi A6 Auto
    By topper in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-01-2008, 05:11 PM
  4. Auto lights
    By shudman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2007, 08:09 PM
