Thread: original Audi A3 Alarm siren
Results 1 to 8 of 8
  1. original Audi A3 Alarm siren
    nagga Guest
    my siren dont work with my alarm. Never heard it.
    alarm does work as the blinkers flash. (flashers)
    i belive the siren is on the left hand side of the boot. beath the sub.
    but i am having trouble..getting down there!!! any ideas
    how do i check or fix the siren...dudes...pls help.
    checked all the fuses....at the front!!!
  2. Re: original Audi A3 Alarm siren
    Exeter
    Hey got the same problem however I had been told the siren is on the near side behind the bumper?
    Any ones help is much appreciated!
  3. Re: original Audi A3 Alarm siren
    nagga Guest
    strange!!! could someone, clear this up!!! and help!! its keeping me up at night!!! lol
  4. Re: original Audi A3 Alarm siren
    Aug 2007
    west midlands, uk
    unlock your door with the workshop key [or without using the fob to unlock it...] that'll set it going alright!!!
    [edit: didnt read thread properly...] try that for jokes anyhoo
  5. Re: original Audi A3 Alarm siren
    Aug 2008
    The siren is located behind the rear LH panel underneath the subwoofer. I came across it when doing some exploring. Best to take off the whole rear panel, start by removing the backdoor trim above the spare tyre, then you might have to remove the rear seating panel, then find the screws for the rear panel (1 above the rear lights inside the compartment, one in the front corner), then you'll have to pull the trim off which can be a bit grim as the clips sometimes break. 3 bolts to take out the sub, then you'll see the central locking pump - cut the cable tie and pull it to one side, you'll now see the siren. Also there is some kind of control box tucked neatly behind the body frame.
  6. Re: original Audi A3 Alarm siren
    nagga Guest
    and then once i get it out.....what do i dont if it dont work. i heard from other threads their is a rechargeable battery in the siren....am not one for solidering irons and fuses....
    whats the quik fix....apart from cough up 80 quid for a new siren....
    its so hard getting to it....the siren can some one whos doing it post some pics
  7. Re: original Audi A3 Alarm siren
    Aug 2008
    Quote Originally Posted by nagga View Post
    Have you tried waving a magic wand at it?
  8. Re: original Audi A3 Alarm siren
    omegadirective Guest
    Quote Originally Posted by gluckster View Post
    LMAO.
  1. a4 cab no alarm siren
    By vinnie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-02-2011, 07:03 PM
  2. alarm siren
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2008, 10:46 AM
  3. No alarm siren
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2008, 04:50 PM
  4. A4 Alarm Siren
    By tigre64 in forum Audi A4 - Archive Topics
    Last Post: 17-09-2007, 05:05 PM
  5. Audi A3 Alarm Siren Not Working
    By Dips in forum Audi A3 - Archive Topics
    Last Post: 13-04-2007, 01:56 PM
