Thread: How do I disconnect the Brake pad wear sensor in the picture ?
Results 1 to 10 of 12
  1. How do I disconnect the Brake pad wear sensor in the picture ?
    London
    Does the sensor unclip, somehow. How do I remove it and how do I reconnect / refit it when I install the new pads, please?
    http://www.flickr.com/photos/27466575@N03/2706205832/
  2. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    7 Post(s)
    Follow the cable up and away from the pad, you will bump into a connector.
    Undo it!
    Simple as.
    However it may take you 5 mins to figure out how the connector works. Be careful and use a small flat bladed screwdriver to undo the clip.
    When you re-fit make sure you route the cable the same way as it was before and also make sure the connector plug is in its holder / clip.
  3. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    London
    Bigcol,
    Thank you for your prompt reply.
    2 minutes ago I bought a new set of front brake pads (£32 for 4) and the new pads come with new sensors - comparing these new ones with my old ones (in the picture) it is clear that 4-5mm of my old pads have worn down.
    Kevin
  4. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    London
    Big Col,
    Thank you - fixed and now time for a beer
    The wiring clips (pad wear sensors) would not snap shut - I will check them tomorrow when my hands are not oily. Maybe a very thin layer of Vaseline will help ?
    Headache56
  5. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    May 2008
    Dude were the pads on the picture your old ones ? if so why did you replace them as there is at least 15000 miles left on them?????
  6. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    Tyldesley, Manchester, UK
    Quote Originally Posted by 1260pete View Post
    There does look a fair bit of lining left, but the sensor is visible. I have just done mine and they had plenty left, but I changed my discs so had no choice .
    One German, Two Italian.
  7. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    London
    Thanks 1260pete and MalcQv,
    The picture of the pad was the one least worn of the two front pads, although I did not know it at the time.
    The pad wear was a little bit uneven on both so that the outer part was less worn that the inner. On the pad not pictured the disc wear had started to mash up the sensor.
    Anyway all now fixed and I thank you for your help. (smiley face)
    However, as the senors only indicate wear of the front pads I have another "5 minute job" to check the rear ones.
    Headache56
  8. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    i hate those sensors , they keep brake companies in business nothing else. i cut the wires at the pad and join them together, this makes the light on the dash go out.
  9. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    London
    Excellent - a pragmatic solution which I will use next time. Cheers.
  10. Re: How do I disconnect the Brake pad wear sensor in the picture ?
    May 2008
    Quote Originally Posted by passat 130 tdi View Post
    Yep me too
  1. A6 brake pad wear sensor light on
    By grasshopper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-06-2008, 11:38 PM
  2. disconnect abs sensor? remove/split track rod end?
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2008, 08:24 PM
  3. brake pad wear warning symbol.
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2007, 05:36 PM
  4. A3 Brake pad wear sensors
    By japeto in forum Chat - Anything with wheels
    Last Post: 27-04-2007, 03:50 PM
  5. Brake Pad Wear Sensor
    By A6-Lou in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2006, 10:22 AM
