Thread: 2.0TDI smoking.
  1. 2.0TDI smoking.
    Ok so its an Altea, but all the same cars under the skin...
    My 2.0TDI smokes. Blue/white smoke thats heavy and lingers - I'm sure its diesel, not engine oil. What colour is diesel smoke? I would have thought it sooty black?
    It only does it briefly when I go from idle or overrun. It doesn't do when I hoof it or accelerate gently after the initial pedal squeeze, just that first 2-400 revs above idle speed. The car doesn't seem down on power (remapped 3 months ago) but I'm leaving clouds of smoke at every junction.
    Presumably something is causing overfueling at the early stage, then correcting. This started after I took off the egr and thoroughly cleaned it (2 toothbrushes, 10 pairs of gloves, 2 tins of carb cleaner and lots and lots of mess) The egr seemed to be actually ever so slightly stuck open with the soot build up (only 27k miles). I checked the diaphragm still worked to open valve and it was sealing correctly.
    I did get a cel light up for approx 20 miles but this has since gone.
    Would a loose air pipe after the turbo cause this as I did change oil at same time and removed cleaned all the pipe work to and from intercooler which had a lot of oil leaking from the dodgy pipe seals and supposedly clean filtered air? A leak of boosted air could lead to a lower charge at inlet manifold confusing the ecu?
    I've ordered vag com so await to see what fault codes are present but would be grateful for any ideas.
  2. Re: 2.0TDI smoking.
    OK vag com shows no fault at all. Now smoking heavily most of the time and its burning engine oil, not fuel.
    Also a faint engine speed/pitch related whine, sounds like a distant police siren. Turbo ******* or is it the tandem pump?
    Turbo still giving full boost - up to 2,5 bar actual and specified and drives fine apart from smoke screen behind car!
    Off to dealers on Wednesday as still under warranty.
  3. Re: 2.0TDI smoking.
    Has now stopped, suspect overfilled with oil and dealer found a loose/leaking/knacked turbo to intercooler pipe
  1. Smoking
    By TUG in forum Passat - Archive Topics
    Last Post: 27-01-2008, 11:08 PM
  2. Smoking A6!!
    By nick127 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-12-2007, 05:33 PM
  3. What to buy A6 2.0TDI or A6 2.7TDI or A4 2.0TDI
    By sanstorm999 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2007, 01:07 PM
  4. smoking !!!
    By plev in forum Audi A4 - Archive Topics
    Last Post: 11-03-2007, 12:52 PM
  5. smoking tdi
    By vivfazer in forum Passat - Archive Topics
    Last Post: 02-02-2007, 09:18 AM
