Thread: My new n75 valve is different
Results 1 to 10 of 10
  1. My new n75 valve is different
    May 2008
    huddersfield
    Trying to change my n75 valve, but it looks totally different. The old one was black, the new one is grey and the outlets are all different.
    Any ideas
    Andy
  2. Re: My new n75 valve is different
    Cheshire
    Hi Mate,
    I hope you dont mind me butting in here, but I keep reading about these N75 valves....what is it for and how do you know if its goosed??
    thanks, and sorry for hi-jacking your post!
    James
  3. Re: My new n75 valve is different
    May 2008
    huddersfield
    As far as i can gather. It is supposed to operate the wastegate on the turbo, when max boost is reached it opens a valve on the turbo that prevents overboosting.
    The symptoms ive got are a trbo that gives loads of boost sometimes and none at others.
    I will let you know if it cures it wen i work out how to connect it.
  4. Re: My new n75 valve is different
    May 2008
    huddersfield
    Overboosting is now cured! Turbo is a lot quieter, no surging and a lot more consistent
  5. Re: My new n75 valve is different
    Cheshire
    Good News!!! Thanks very much for your help mate!
    Happy audi-ing
  6. Re: My new n75 valve is different
    Jul 2008
    mine is also behaving alot like that and boosting when it wants to....couldnt find wat it was as it wasnt bringing up any codes on the computer mine is remaped and goin off what people have told me the n75 valve stop functioning properly and stops it from boosting properly so am goin for a race one i have found on the net. see how it goes
  7. Re: My new n75 valve is different
    130 Post(s)
    1972 Post(s)
    A race N75? It is just a solenoid controlled by the ECU. Mind you the Eaton ones for the 1.8T petrol supplied by VAG (made in Monaco of all places) are rubbish. I had one fail on my Octavia last year so I fitted a new one. For the last year I have had an intermittent light acceleration pulsing problem that I haven't been able to cure as I could only grab a few minuets here and there (flaming customers!). Last week I thought I would spend a morning on it and stripped the boost system down as I knew it was a boost issue. I bought the full VAG boost pressure leak test system (£400 odd) and the system was as tight as a ducks bottom, so to speak. So I fitted a new throttle body, no different, a new N249 solenoid-no different so in the end I pulled the new N75 off, tested it and the dammed thing was leaking! Under slight acceleration it was popping the wastegate open very slightly. Now the throttle response is perfect under light throttle and on a cruise to Rochester and back I was getting 45mpg at naughty ish speeds where before I would have seen 35mpg. Needles to say VW will be getting the old N75 back as it has a two year warranty-the beauty of genuine parts.
  8. Re: My new n75 valve is different
    Jul 2008
    yeah a mate told me bowt it ...apparently they are slightly different in that the dont mess up you boost when you have had the car remapped
    After remapping of the ECU on some VAG 1.8 Turbo vehicles there can be a certain amount of surging that can occur as the car is engine is prevented from over boosting. By simply replacing your vehicles standard N75 valve with the 'J' version this should overcome this issue and give a far smoother and more enjoyable drive."
    ......a will try it n see wat happens ...fingers crossed
  9. Re: My new n75 valve is different
    May 2008
    huddersfield
    The one i got from audi is totally different, its made by pierburg. It has transformed the car though. Was 50 quid from the dealer. Have heard mixed reviews on the race ones.
  10. Re: My new n75 valve is different
    Jul 2008
    will go to dealers and try tht one thn ...a dont fancy spendin 55 quid on summit what turns out to be a load!!!
  1. A3 EGR Valve
    By Adrian24 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-05-2008, 07:40 PM
  2. What valve is this...???
    By vw_lee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2008, 12:30 AM
  3. N95 j valve
    By pgarner in forum Chat - Anything with wheels
    Last Post: 25-03-2008, 07:29 AM
  4. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
  5. N75 Valve
    By rick in forum Archive posts
    Last Post: 02-02-2007, 08:41 PM
