Thread: WYNNS Egr Cleaner
  1. WYNNS Egr Cleaner
    Jun 2008
    HI,
    I drive a 2004 plate golf 1.9 tdi with 50,000 miles on the clock. After taking off the pipe going into the inlet manifold flap motor, i seen a bit of carbon, could i spray the egr cleaner directly into here with no worries??
    Wynns directions for use say - Is the flexible hose in there instructions the same one which comes round into the inlet flap motor and egr valve??
    Directions
    • Start the engine until its warm.
    • Remove the flexible hose in the air intake system, situated between the turbocharger/intercooler and the air intake manifold.
    • Let engine run at 2000 rpm.
    • Spray the product, with short intervals, into the air intake manifold.
    • Rpm and diesel knocking can rise during pulverization.
    • After each pulverization, wait until original set rpm is regained.
    • If necessary accelerate to avoid engine stalling.
    • Continue until the 200 ml of product in the aerosol are consumed.
    • Let the engine run at idle during a few minutes.
    • After this idling period, accelerate the engine approximately 5 to 10 times or drive 5 to 10 km.
    • Do not exceed 3000 rpm.
    • Stop the engine.
    • Put hose back in place.
  2. Re: WYNNS Egr Cleaner
    Unless the manifold is thick with deposits I'd leave it alone. EGR valves are so bloody delicate. Speaking from experience!
  3. Re: WYNNS Egr Cleaner
    Jun 2008
    well ive got a code from the diagnostic as "egr valve recirculation insufficient" thats why i had it off, so was wondering wether i cud spray it through the flap motor to save removing it all, as when i put finger onto the flap this was thick with carbon
  4. Re: WYNNS Egr Cleaner
    Apr 2009
    My local mechanic did this to my previous Golf, a Mk4 1.9 GTTDI 110bhp which had approx 120K on the clock. In the end I changed the EGR valve myself - a bit messy - cost me £98 - but made all the difference. You can take the EGR off and give it a good clean - somebody recommended brake fluid and as I'd just bled my brakes I used the old stuff and it really cleaned it up like new. I found a site on the Web explaining how to clean the EGR.
  1. Diesel injector cleaner
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2008, 12:08 PM
  2. Have you used Innotec turbo cleaner?
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 06:10 PM
  3. Injector cleaner Worth it ?
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2007, 10:05 AM
  4. Cleaner engine bay
    By Jay121 in forum Chat - Anything with wheels
    Last Post: 17-04-2007, 09:20 PM
  5. diesel cleaner?
    By dieselal in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-02-2007, 05:33 PM
