Thread: Replacing Fabia windscreen wipers
  1. Question Replacing Fabia windscreen wipers
    damper Guest
    On seeking replacement wipers for my 53 reg Fabia 1.4 16v I found that the passenger side one is curved. Replacements recommended in stores like Halfords, however, are available as either curved or straight. is there a particular advantage in the curved version, or is it OK to fit what is available?
    Has anyone a recommended replacement manufacturer?
  2. Re: Replacing Fabia windscreen wipers
    damper Guest
    Silence reigns! Skoda owners do not warrant a reply
  3. Re: Replacing Fabia windscreen wipers
    pastyboy Guest
    Quote Originally Posted by damper View Post
    Hello,
    You need only replace the wiper blade & holder, which is straight , and not necessarily the arm it is located on, which is curved.
    Removal of the arm itself from its splined position stud requires a puller, as it will be extremely tight. Corrosion would have set in being an alloy arm and the spline is made of steel, and rust doesn't help either.
    Your request for help is rather dated so assume you have approached the likes of "Halfords" to aquire a replacement for the offending blade.
    Good luck. pastyboy 20/03/2009
  1. Wind deflectors and windscreen wipers...
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-06-2008, 12:14 PM
  2. windscreen wipers
    By RS4Molar in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-04-2008, 10:43 PM
  3. Windscreen Wipers
    By stevepil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-03-2008, 01:17 AM
  4. B6 Saloon windscreen wipers
    By GilesC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2007, 06:08 PM
  5. Windscreen Wipers Question
    By DaleB in forum TT - 8N Forum - 1998 - 2006
    Last Post: 23-02-2007, 02:04 PM
