Thread: bulb blown in high level brake light. MOT failure?
Results 1 to 8 of 8
  1. bulb blown in high level brake light. MOT failure?
    Bournemouth
    my mate has a saab 900 convertible, and one of the filaments has gone in his high level brake light. there are about 6 filaments in the light in total, the rest operate fine.
    would this fail an MOT?
    thanks
  2. Re: bulb blown in high level brake light. MOT failure?
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by dansansome View Post
    thanks
    I would have thought it would go down as an advisory, providing the brake lights in the clusters work.
    Paul
  3. Re: bulb blown in high level brake light. MOT failure?
    Bournemouth
    thanks
  4. Re: bulb blown in high level brake light. MOT failure?
    Manchester, England
    I had a similar problem in a previous car, the guy at the garage advised I could either get it fixed or just cut the wire, hence disabling the rest of the lights which apparently was fine as it is classed as an extra brake light. 1 light out meant a fail but all the lights on/off meant a pass
  5. Re: bulb blown in high level brake light. MOT failure?
    May 2008
    Hi, As an M.O.T. tester, i can say the "3rd" brake lamp pass / fail criteria is a bit of a gray area. however, in your case, if the lamp is of multi bulb type and only one has blown, this is not a reason for rejection, it would be a pass with a possible advise. hope this helps. Austin.
  6. Re: bulb blown in high level brake light. MOT failure?
    Bournemouth
    excellent. just what i was after.
    many thanks Austin
  7. Re: bulb blown in high level brake light. MOT failure?
    Feb 2007
    Nottingham
    Quote Originally Posted by austindarrell View Post
    What that man said, though it makes Nil sense to me. It wouldn't be to hard to change anyway if you really wanted
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  8. Re: bulb blown in high level brake light. MOT failure?
    Bournemouth
    yeah, i know, i was asking for a friend who originally thought that the light was buried behind a load of awkward trim. he asked me the question, and i didnt know, so i thought i'd put it up for the gurus on here
    as it turns out he got to it pretty easily, and it appears to be a dodgy contact as the bulb works intermittently.
  1. re: high level brake light
    By robins1uk in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 11:34 PM
  2. High Level Brake Light
    By cunningm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 03:41 PM
  3. High Level Brake light
    By richard01276 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2007, 08:54 PM
  4. Golf MK IV High-Level Brake light
    By Braby in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-06-2007, 04:38 PM
  5. Only the high level brake light and flahing coil light
    By 49forever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 04:41 PM
