Thread: 95 gti won't idle, sometimes !
  1. 95 gti won't idle, sometimes !
    Llanelli, south wales
    I have a problem with my 95 8v gti, where it will not idle properly and will cut out on the first junction i come to. It will restart immediately and not die again on that jurney, though it will hunt for revs.
    But then sometime it gets worst, when i try to start the car i have to keep my foot on the accelarator to keep the revs up or it will die. Making it impossible to drive as i'm no good at left foot breaking ! This has resulted in me having to use a clothes peg under the bonnet on the throttle body to keep it open slightly to get me home. This problem then seems to clear for a couple of weeks before returning, though the first problem is constant.
    Help would be very much appriciated.
  2. Re: 95 gti won't idle, sometimes !
    7 Post(s)
    Do a search on here for throttle body cleaning / alignment.
    Probably caused by a combination and / or either;
    1, Dirty throttle body
    and / or
    2, Throttle body needs to be electronically aligned.
    and / or
    3, The throttle body is faulty, note that replacement will need to have the electronic alignment carried out on it.
    As above, do a search for lots more info.
  3. Re: 95 gti won't idle, sometimes !
    129 Post(s)
    1972 Post(s)
    I agree, remove, clean and reset (using VAG-COM or similar) the throttle body and also have the fault memory read for codes and any found read, printed and cleared.
  4. Re: 95 gti won't idle, sometimes !
    Thanks for that.
    Anyone know of a good Garage with VAG-COM around the Swansea area.
  5. Re: 95 gti won't idle, sometimes !
    well i've sorted that problem with no need for vag.com or removing the throttle body.
    What done it for me was simply removing the pipe from the airbox to the throttle body and holdind the butterfly valve open and simple cleaning it all down with a rag.
    The car has now run for over a month without a glitch.
    Thanks for pointing me in the right direction.
  1. Will not idle
    By racer in forum 80 - 90
    Last Post: 11-05-2008, 07:27 PM
  2. A4 1.8 Not Quite Idle
    By pelops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-12-2007, 07:55 PM
  3. hello?? a3 idle issues
    By weebrads in forum Audi A3 - Archive Topics
    Last Post: 15-09-2007, 01:02 AM
  4. What should a 3.2 idle at?
    By Space Cadet in forum Audi A3 - Archive Topics
    Last Post: 15-08-2007, 01:50 PM
  5. Idle speed and air con ?
    By stswmc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2007, 09:39 PM
