Thread: A4 Convertible Alloys fit a vw t4?
Results 1 to 10 of 10
  1. A4 Convertible Alloys fit a vw t4?
    Jun 2008
    Hi sorry if this is in the wrong section (newbie - doh)
    I've been offered some mint A4 16" alloys off a 18month convertible.
    Can anyone tell me if they will fit a VW 98 swb T4 Transporter? According to my mate they have ET50 on the inside of the rim if this helps?
    Many thanks
    MOOSE
  2. Re: A4 Convertible Alloys fit a vw t4?
    Oct 2005
    Transporter has a PCD of 5x112 an ET of 25 to 42 and a centre bore of 57.1
    As long as these new wheels are the same PCD everything else can be overcome.
  3. Re: A4 Convertible Alloys fit a vw t4?
    Jun 2008
    Thanks for the reply. Will the offset of 50 be a problem, ie rubbing on the rims or similar then?
    cheers again
    Moose
  4. Re: A4 Convertible Alloys fit a vw t4?
    Oct 2005
    If your current rims have an offset of 25 (ET 25) then (assuming the new rims are the same width as the old rims) fitting ET50 will suck the wheels 25mm.
    The inner lip of the rim will then, more than likely, foul on the suspension struts. Asthetically, it'd look odd as well, with your rims being 25mm further "into" the arch
  5. Re: A4 Convertible Alloys fit a vw t4?
    Coventry
    so would you need a 25mm spacer?
    i know nowt abot this so just learning
  6. Re: A4 Convertible Alloys fit a vw t4?
    Oct 2005
    Yup, that would give the new rims the same ET as the old ones
  7. Re: A4 Convertible Alloys fit a vw t4?
    Canada
    Quote Originally Posted by golfmk5gttdi View Post
    Yes that will work, but remebers its a Van so the loading is greater, so not recommended, also you should get Van rated alloys for the same reason.
  8. Re: A4 Convertible Alloys fit a vw t4?
    Jun 2008
    This is getting confusing
    My standard vw steelies have the following on the rim
    6J15H2 DIN DOT D15x6 ET55
    and are running the following tyres
    195/70/R15C 104/102R max load 900kg
    The Audi alloys have the following on them
    6.5Jx16H2 ET50
    and the tyres are
    205/55R/16 90V max load 600kg
    Does this extra info help diagnose if they're ok or not
    HEEEEELLLLLLLLLLLLP!!!
    Cheers again
    MOOSE
  9. Re: A4 Convertible Alloys fit a vw t4?
    Oct 2005
    Right, facts and figures at last
    Current set up
    • Width - 6J
    • Size - 15
    • Offset - ET55
    • Tyres - 195/70/R15C 104/102R max load 900kg
    Potential set up
    • Width 6.5J
    • Size - 16
    • Offset - ET50
    • Tyres - 205/55R/16 90V max load 600kg
    OK!
    The tyres on the new wheels are not only the wrong load rating they're also the wrong size so your speedo will misread. Ideally you'd want 205/60/16 or 195/65/16 - depends on what is the cheapest in the correct load/speed rating.
    The inner edge of the new wheels will sit 1mm further in than the original wheels. The outer edge will stick out an additional 11mm.
  10. Re: A4 Convertible Alloys fit a vw t4?
    130 Post(s)
    1972 Post(s)
    Ohh look, more spam for me to enter my credit card details into, ohh joy and fun, let me enjoy destroying my credit rating. All spammers must die!
  1. 1.8 8V Convertible overheating.
    By sportline in forum Golf MK1 - 1974 -1984
    Last Post: 17-09-2008, 11:49 AM
  2. 1997 convertible 1.8
    By JimSharp39 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 17-02-2008, 05:20 PM
  3. Convertible Key Question
    By BEEGOLF in forum Golf MK4 - 1999 - 2004
    Last Post: 02-01-2008, 01:28 PM
  4. A4 convertible Aerial
    By jgoggins in forum Audi A4 - Archive Topics
    Last Post: 06-06-2007, 11:59 AM
  5. a4 convertible
    By milliemoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2007, 05:40 PM
