Thread: Phaeton Owners with problems?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. Unhappy Phaeton Owners with problems?
    IS anyone having HUGE quantities of warranty claims on their Phaeton?
    I've had new: Tail lamps, sat-nav cd-rom, cd changer, cpu screen, speakers, headlight washers, door skins, batteries and still the car doesn't work properly. Lovely car but so unrelentlessely(?) unreliable!
    Dec 2006
    to be honest i have not heard of any issues along my travels...
    Would be good to hear from other oweners tho!
    Just checked and theres no recalls...
    "There is currently no recall data available for the 2006 Volkswagen Phaeton."
    RicKT
  3. Angry Phaeton problems
    It would be depressing to think that I had a "friday afternoon" car, although I did orignally suspect that my problems are as much associated with the dealer as with the vehicle. Many small repairs in 5 months wouldn't be so frustrating if the main CPU screen/computer hadn't been intermittently faulty for the entire time.
    Again, please post thoughts for any Phaeton owners with problems!
    Chris
    Dec 2006
    i know some one that had a "Friday Afternoon car" and the CAM belt went at 10K, wheels beraring at 20K.. electrics at 30K and then got shut... it was a Audi A4 1997...
    Any other Pharton owners out there please come foraes..
    RicKT
  5. Question Some problems - nothing major
    Apr 2007
    I have had a bundle of things done to mine but I have to admit that most of the visits to the workshop were through dealer incompetence in not diagnosing the problems properly or failing to agree they exisited - "Computer says no!"
    ANyway.....in no particualr order....
    - New centre console bin lid - broken catch
    - New rear centre air vent (LED intermittent)
    - New centre console wood trim - to eradicate gearstick vibration under frull throttle
    - New front centre cup holder mechanism
    - New n/s headlamp washer - they swore it worked and had checked it thoroughly, took me out to prove it....... and it didn't work! Got fixed on THIRD visit!
    - New antenna booster amplifier - Radio reception was VERY bad, TV ok
    - Replaced main cable between Info-Tainment unit and main CPU - was told this would absolutely sort the radio problem above. It didn't.
    - A new main info screen fitted - don;t know why and was never told but the original had a mark/blemish in it that could only disappear through replacement
    - Rear centre console bin mechanism is broken (yet to be fixed)
    And from memory I think that's it.... other issues to date.... blow-out, flat-spotted wheels, new front pads, first service (£350 oil change) and that's about it. Which seems a lot but its across 35,000 miles and none of these problems has been persistent or recurrent.
    I'm off now to get "Exhaust - Workshop" warning checked out at the dealer which is not covered in the manual except for Petrol cars. which mine is not.
    P
    May 2007
    Quote Originally Posted by RickT View Post
    RicKT
    Hi. Apparently there IS a recall. Dash clocks. I'm booked in for the end of June. Check it out with your dealer.
    Incidentally I've had a new steering rack and new wheel embellishers under warranty.
    Clive
  7. Exhaust Workshop
    Apr 2007
    Thansk for the info Clive - I haven't been back for a clock yet but funnily enough I am getting an unusual, but subtle, noise from the steering on full lock.
    The fault three weeks ago was an air mass sensor failure. As usual it was not in stock and I could only get a courtesy car (non prestige) for the end of May - a month long wait! A prestige coutesy car would have been some time in JULY!!!
    Anyway, having been told it was OK to drive in the meantime I then got engine management failure light on about 500-800 miles later which cut power by, at a guess, 50% + 50mph max and 0-50 in about 30/40 seconds! The diagnostics came up as Turbocharge underboost in additon the sensor fault.
    However, VW Luxury Assist got me a hire car almost instantly and the dealer fixed it the next full working day. Apparently it was just the air mass sensor and I',m guessing that after so many miles of a warning being on the engine management kicks in to insist you get it sorted. Not a bad idea really.
    Pete
    Mar 2007
    West Yorkshire
    Only problem I've had is the wipers won't park for blade changing or screen cleaning, but I can live with that until it needs servicing. Just think yourself lucky you haven't got an Eos
  9. Re: Phaeton Owners with problems?
    Jul 2007
    Hi all
    My first posting
    I have 3.0 TDi Phaeton with to many problems for a 36K car
    Flat Aux battery, Tv aerial,comfort controller ,bold front tyers
    after 8K miles,and now just be informed it needs a new gear box
    Only has 14K on the clock
    I think its time to change
    Quote Originally Posted by hbz3 View Post
  10. Re: Exhaust Workshop
    Quote Originally Posted by phatone View Post
    Pete
    am looking to buy said car can you give me honest opinion of specs thanks linda x
  1. Phaeton Headlight Converter
    By Clive Russell in forum Phaeton
    Last Post: 05-04-2012, 03:10 PM
  2. Any W8 owners here ???
    By Jabba in forum Passat - Archive Topics
    Last Post: 31-01-2007, 01:09 AM
  3. Any V5 2.3 owners here
    By Bajie in forum Passat - Archive Topics
    Last Post: 24-01-2007, 06:09 PM
  4. Replies: 0
    Last Post: 05-05-2005, 07:56 PM
  5. Phaeton
    By stuart in forum Phaeton
    Last Post: 26-04-2004, 11:02 PM
