Thread: clutch replacement needs new dual mass flywheel???
Results 1 to 10 of 18
  1. clutch replacement needs new dual mass flywheel???
    Oxfordshire
    Audi a4 avant 1.9tdi. Clutch is 26k and 2yr 3mnth old. Audi had replaced flywheel and clutch at 92k now at 118k. Twice we couldnt engage gears and had to start it up in gear and bugger about to free it off. These incidents happened to the misses with our 10 month son and once on the M40 with RAC recovery so needed sorting out. Audi wouldnt discuss any possibility of discount outside the warranty until they stripped it so not worth risk of them saying yes its faulty but no we wont pay out.
    Took it to local Audi/VW specialist. Said some drag on the clutch (selecting gears with engine running was harder than with engine switched off). Agreed take it apart, look, then possibly replace clutch. they found the spigot bearing disintegrated so said will replace it and replace clutch too.
    Few days later asked on progress. Slight judder in first on pulling away needs reinvestigating. Few days later asked again, said the spigot bearing breakup may have damaged flywheel so pay the bill and try it to see if it settles in or pay for new flywheel and they'll cover labour for removal again to do it. They mentioned they removed flywheel to fit spigot bearing which added another 1/2 hour labour.
    There was no judder at all before they did this job so anyone knowledgable on the subject got any useful comments? I though judder was from warpage or overheating and would show up before a new clutch was installed. Thanks all. Mark.
  2. Re: clutch replacement needs new dual mass flywheel???
    Oxfordshire
    Spigot bearing - means the bearing that locates the gearbox input shaft I think.
  3. Re: clutch replacement needs new dual mass flywheel???
    Mar 2007
    coventry
    if you need a new clutch then it is advised to replace the dmf at the same time as to save doing two jobs just weeks apart.
    no matter how you try you always come back to what you first started
  4. Re: clutch replacement needs new dual mass flywheel???
    129 Post(s)
    1972 Post(s)
    Agreed, there is no way I would change a clutch only on a DMF equipped car. The only course of action now is to pull it apart and do it all over again and that includes the clutch again. These are so much work to do that you should not take the chance of having a problem again.
  5. Re: clutch replacement needs new dual mass flywheel???
    Oxfordshire
    thanks, i havent actually collected the car from them yet so was looking for advice as Im not happy to take it with a judder. So are you saying that just by fitting and trying the clutch with the old DMF they've knackered it already?
  6. Re: clutch replacement needs new dual mass flywheel???
    129 Post(s)
    1972 Post(s)
    Quite possibly and no one in their right mind would chance it.
  7. Re: clutch replacement needs new dual mass flywheel???
    Agreed. If you kick off you should be able to get them to cover the clutch too i would have thought? Beginners error not changing both together - or at least not very carefully checking the DMF.
    A knackered clutch will take out a DMF pretty quick, and vice versa. If its juddering, its putting undue load through the clutch. It might be juddering because the DMF moving around bent the unidirectional drive straps.....
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  8. Re: clutch replacement needs new dual mass flywheel???
    Oxfordshire
    Had the car back, clutch judder whilst only slight is unacceptable and worse on uphill starts so it'll go back after bank holiday. Not paid anything yet.
    What I'd hoped to discover from someone is why a judder might occur after a new spigot bearing was installed along with a new clutch when it didnt have any judder before?
    Remember it was a failed spigot bearing that was the problem causing drag on the gearbox shaft rather than the clutch or flywheel failing but the clutch was changed anyway as the box was out. It had only done 26k as has the flywheel too.
    I was told the flywheel was removed to change the spigot bearing and the garage suggests the gearbox shaft may have damaged the flywheel and now it's refitted, it's causing the judder and needs replacing - does anyone know if the spigot bearing goes in the end of the crank or in the centre of the flywheel and does this explaination sound plausable or ********?
    Thanks for comments so far.
  9. Re: clutch replacement needs new dual mass flywheel???
    129 Post(s)
    1972 Post(s)
    The spigot goes in the end of the crank and when it fails it often damages the end of the input shaft but that will not cause judder unless it was wrecked and if it was, they should not have re-fitted the box. If it is juddering and the clutch is a reputable new make then it has a faulty flywheel. I guess they will be pulling it apart again.
  10. Re: clutch replacement needs new dual mass flywheel???
    Oxfordshire
    Thanks for your input Crasher.
    As it didnt judder before pulling apart, any suggestions why it would judder after fitting a new clutch and spigot and puttting together? Also, do spigots come with clutch kits or are they seperately purchased items?
  1. Dual Mass Flywheel - OE or Not OE
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2010, 01:30 PM
  2. Dual mass flywheel and Clutch
    By nano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 08:38 PM
  3. Dual Mass Flywheel
    By seventh-heaven in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-11-2007, 07:19 PM
  4. dual mass flywheel
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 01:22 PM
  5. Dual Mass Flywheel
    By Richardm in forum Passat - Archive Topics
    Last Post: 27-03-2007, 02:54 PM
