Thread: Temperature gauge not working
Results 1 to 8 of 8
  1. Temperature gauge not working
    Dec 2006
    Hi Folks!
    Golf Mk2 1988 1.3 5dr
    I've noticed that the temperature gauge is not working on the dash, along with an intermittant fault on the radiator fan. Could these two be linked?
    Any suggestions as to how to fix either or both will be greatly appreciated.
    The fan takes it's signal from a switch on the rad and the gauge in the car takes its reading from a separate sender.
    Regards Boardboy
    Dec 2006
    Thanks Boardboy.
    Managed to sort out the fan problem but the temp gauge
    still dosn't work. Any suggestions anyone?
    hi, did you fix your temp gauge because i'm having the same prob?
    Canada
    Have you tested the gauge? you can do this by taking the wire connected to sender and disconnecting it and shorting it to ground. if the gauge goes to the hot position then its the sender, if not its the wiring or gauge itself.
    Rob
    i'm not entirly sure where the sender is?
    Canada
    I would suggest getting a haynes manual as this will be a great help. I only have experence of the 8v GTI engine and its situated on the union that comes from the block and goes to the radiator via a hose.
    Rob
    Dec 2006
    Yes I did.
    It was the temperature sender unit/switch.
    I have a 1988 1.3 and there are two sender units that are connected to the thermostat housing. I changed both, at a cost of £15, and now the temp gauge works.
    Good luck with yours.
  1. Temperature gauge on zero / fan very noisey
    By jtlowrey in forum Audi A3 - Archive Topics
    Last Post: 11-06-2007, 11:45 AM
  2. Temperature gauge not registering
    By A4Sline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2007, 04:01 PM
  3. A4 Temperature Gauge not reading
    By GT001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2007, 04:11 PM
  4. Exterior Temperature Gauge
    By Happy Owner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-01-2007, 04:02 PM
  5. temperature gauge
    By cat69 in forum Archive posts
    Last Post: 10-11-2006, 10:23 PM
