Thread: 2001 A4 Headlight removal/bulb replacement
Results 1 to 10 of 19
  1. 2001 A4 Headlight removal/bulb replacement
    Dec 2006
    Have just had a Nightmare trying to replace passenger side dipped beam bulb on my 2001 A4. Can anyone advise on easy procedure? Is it better to completely remove headlight to access bulbs? if so, How do I get The headlight out?
  2. Exclamation
    Dec 2006
    Hi there,
    Have a look at this guide i have wrote.
    http://www.audi-forums.com/b6-forum/...ght-guide.html
    RicKT
    Dec 2006
    and the answer to your question is yes... the best way is to remove the headlight unit.. it can take a bit of time on your first go!!
    RickT
  4. Re: 2001 A4 Headlight removal/bulb replacement
    SP2 A6 Guest
    I know this is resurrecting an old post but is there something similar for an A6 (1999)? I need to replace a headlight lens (which costs £25 from Hella) and the ******* is quoting £500 for a whole new headlight....
  5. Re: 2001 A4 Headlight removal/bulb replacement
    Apr 2007
    Lancashire
    Normal procedure is to take all the skin of your fingers, then drop the bulb on the floor.
  6. Re: 2001 A4 Headlight removal/bulb replacement
    Dec 2006
    Quote Originally Posted by ini View Post
    This headlights are "sealed" units, however if your careful you can take them apart simple enough.. be carful not to break it!!
    In regards to a guide.. i have not seen on..
    RickT
  7. Re: 2001 A4 Headlight removal/bulb replacement
    Jul 2013
    United States
    Quote Originally Posted by RickT View Post
    Hi there,
    ##B6 Front Headlight & Tail light Guide! ## - Audi Forums
    RicKT
    Absolutely useless. What good is a B6 guide going to do someone with a B5? "Need help with a B5 headlight? Here's a B6!"
  8. Re: 2001 A4 Headlight removal/bulb replacement
    Oct 2005
    Welcome to VWAF
  9. Re: 2001 A4 Headlight removal/bulb replacement
    Jul 2013
    United States
    Welcome to VWAF
    Thanks!
    Anyone actually know how to remove the headlight on a 1999.5 - 2001 B5 A4? I know theres a way to do it without taking off the bumper but no one seems to post how. I see pre-facelift guides and B6-on guides everywhere though.
  10. Re: 2001 A4 Headlight removal/bulb replacement
    Oct 2005
    AudiWorld Tech Articles
    No photos, but that should give you an idea.
  1. Headlight bulb replacement
    By alistairvw71 in forum Touran - Sharan - Caravelle
    Last Post: 01-07-2009, 05:13 PM
  2. Passat 2006 Headlight Bulb Replacement
    By Jaspercat3 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-11-2008, 09:39 PM
  3. Changing Headlight bulb in A4 2001 (newshape)
    By moss in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2008, 01:05 PM
  4. Headlight bulb replacement
    By MalcQV in forum Passat - Archive Topics
    Last Post: 21-10-2007, 03:32 PM
  5. headlight bulb
    By peecee in forum Passat - Archive Topics
    Last Post: 26-11-2006, 09:15 PM
