Thread: Jacking points with a trolley jack
Results 1 to 10 of 10
  1. Jacking points with a trolley jack
    On my old Peugeot if I need to lift the front of the car up to get to the sump nut, I use a block of wood and a trolley jack and lift from the sub-frame and then support the car using axle stands on the jacking points on the sills.
    The Haynes manual for the Passat says I should not do this. Where do you guys jack the car up from if you need to lift it up completely and evenly?
    I managed to change the oil tonight by lifting on one side and using an axle stand under the where the wishbone joines the subframe to be safe. I could buy a second trolley jack and lift each side, but this seems excessive.
    I saw a thread where somebody lifted the rear of the car via the towing eye which doesn't sound great.
    Any help would be appreciated.
    Rob
    2004 Passat PD 130TDI 4-Motion
    2006 Audi A3 1.9TDI Sportback
    1990 Peugeot 205 1.9 GTi
  2. Re: Jacking points with a trolley jack
    ireland
    why not buy a pair of car ramps,cheaper and safer,see ebay or halfords.
  3. Re: Jacking points with a trolley jack
    Quote Originally Posted by paulp View Post
    I have a pair of ramps and I do use them occasionally, but there are occasions when you need to lift the car and take the wheels off so you can't use a ramp.
    For example changing the gearbox oil, the car needs to be level but the wheel needs to be off to access the filling hole. Changing the clutch needs the wheels off to remove both driveshafts.
    I already have a decent trolley jack and stands so cost isn't an issue, just convenience.
    Any other suggestions / help?
    Rob
  4. Re: Jacking points with a trolley jack
    Nov 2006
    I have had the same question myself, the Haynes manual says use axle stands under the jacking points only, but how do you raise the car to get them in ?.
    Instead of axle stands I have got a number of large wooden blocks which I can get closer to the trolley jack than axle stands. I put the trolley jack pad so its middle is a couple of inches forward of the jacking point centre line, then raise the car and slide the wooden blocks in. Using this method the blocks are right up to the jacking point and the load of the car is spread over a large area. This has been fine for several large jobs and is very safe.
  5. Re: Jacking points with a trolley jack
    Ashbourne Derbyshire UK
    I have the sport model & the suspension is lower & i cant drive up the ramps without catching the underside of the bumper. My only option is jack / axle stands !
    Once owned 98 1.8 ADR SE non turbo passat estate(The Mrs wrote it off)
    Now own 03 TDI 130 Sport 6 Speed passat estate
  6. Re: Jacking points with a trolley jack
    Quote Originally Posted by vincentbob View Post
    Hmm, so you lift it from one side, slide the block in and then lift from the other side and slide the block in? Aren't you at risk of the block moving when you jack from the other side?
    If I only wanted to lift one side, I would jack from the sill and then use the axle stand under the bottom of the wishbone where it bolts into the subframe which should be solid enough.
    Looks like there isn't a good way to life the whole car from the front unless you have two trolley jacks or a 4-post lift!!
  7. Re: Jacking points with a trolley jack
    Nov 2006
    The wooden blocks I use are about a foot square and 2" thick, I jack it up each side in turn until the wheels are off the ground. Long winded but safe and the method I used when I had the gearbox out.
    For normal servicing I use ramps, mine is a sport and I use, yes; wooden ramps made of 6" x 2" about 2'6" long. I have added a couple of slats at one end which hook on the top rung of my steel ramps, and I have tapered the ends so the car drives smoothly onto them. These ramp extensions ensure that the front valance doesn't hit the ramps.
  8. Re: Jacking points with a trolley jack
    London
    Rob,
    I had the same problem. I have just had the car up on a trolley jack (with axle stands) fro 2 days while I changed a driveshaft.
    I put my trolley jack under the place shown on theh atatched photo. http://www.flickr.com/photos/26189143@N02/2456799757/
    I am no expert but it seemed to work fine.
    hedache56 / Kevin
  9. Re: Jacking points with a trolley jack
    Jun 2008
    Hi , buy an oil syringe ( € 90 ) and you can change the oil thro the dipstick tube. Oil filter is accessable from the top of the engine. I can do the oil change ( sucking out while i change the filter ) and filter change in clean clothes in approx 30 min. That`s every 5K miles . For the 10 K service I drive my 130 sport ( low suspension ) onto two wooden blocks , about 1.5 inches thick before going onto the ramps, the bodywork will then clear the ramps. When on the ramps you can remove the under pan which reveals the crossmember where you can position the trolley jack, jack up, and replace the ramps with the axle stands at a suitable loc. When on the ramps I raise the back of the car onto axle stands, get it level and check the g/box oil. Mine needs a i/2 pint of g/box oil every 10 K with no visable leak. ....worth checking. rgds....dannyboy 201062
    Quote Originally Posted by headache56 View Post
    Rob,
    hedache56 / Kevin
  10. Re: Jacking points with a trolley jack
    Tyldesley, Manchester, UK
    Me too.
    The lower valance catches the ramps so I use a couple of pieces from old flags placed in front of the ramp. The car is lifted slightly by them before I go up the ramps.
    I have just swapped around my front to rear wheels and used my trolley jack really close up to the wheel at the front, then the standard jack that came with the car at the rear. This of course only lifts one side not all the front of the car.
    One German, Two Italian.
  1. obd jack location on 96 cab airbag fault
    By pedro B in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-03-2008, 07:21 PM
  2. So I've damaged the sill of the car with a jack...
    By dwalker109 in forum Archive posts
    Last Post: 26-01-2008, 05:01 PM
  3. Jacking Points
    By Ben in forum Chat - Anything with wheels
    Last Post: 13-10-2007, 10:51 PM
  4. jacking
    By lawrend in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 02:24 PM
  5. Audi A4 Car Jack
    By stua4 in forum Audi A4 - Archive Topics
    Last Post: 04-02-2007, 12:50 AM
