Thread: Audi A3 airbag light
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Audi A3 airbag light
    hello
    supposedly the owner said it was a sensor under the seat i think which the part will cost around £80 then labour on top to fit it, but will this turn the airbag light off?
    yes its a 3 door
    thanks
  2. Re: Audi A3 airbag light
    Mar 2008
    Quote Originally Posted by gilly_15 View Post
    hello
    yes its a 3 door
    thanks
    It might not be a faulty sensor, it could simply have been triggered off by accident. Try getting the fault code cleared by someone with a diagnostic kit (expect to pay £40 - £45) and see if that cures the problem.
    It's always best to try the cheapest cure first
    Cheers,
    TheEggShell
  3. Re: Audi A3 airbag light
    Took it to mate tonight, diagnostic said faulty front airbag sensor (one by the headlight). He's going to order the part tomorrow (Audi only item, surprise surprise!).
    I'll keep you posted!
  4. Re: Audi A3 airbag light
    I had the same fault on my TT and it cost £25 to fix from an independant VAG garage. Apparently a very common fault.
  5. Re: Audi A3 airbag light
    Apparently it can be set off quite easily, but mine picked up a fault that couldn't be reset, malfunction in the front drivers side sensor.
  6. Re: Audi A3 airbag light
    Emission system warning light on now, starting to wich I'd got rid of the car already!
    Morale of the story - sell it before the warranty runs out!
  7. Re: Audi A3 airbag light
    #17
    hello
    i took it to my mechanic today it came up on his diagnostic as the front passenger side, he thinks most probably it is the sensor in the front bumper i think, therefore he is going to replace that sensor and see if it fixes the probleem with my airbag light. as he tried resetting it but it still came back!!!
  8. Re: Audi A3 airbag light
    #18
    Mar 2007
    Quote Originally Posted by TheEggShell View Post
    Is the car a 3 door? If so...
    The airbag sensors are under the passenger seat. Moving the seat forward and backward when people get in and out of the back can sometimes set the sensor off.
    A simple rest of the fault code (£40ish at a garage or some beer tokens for a friendly Vag-Com owner) could well solve the problem. Of course, it could always be a geniune error in which case the fault code and warning light would re-appear.
    One thing to bear in mind is that your airbags won't deploy when the warning light is on so I'd get it sorted sooner rather than later.
    i have this problem and it is caused because the wiring in the seat has dried out and stuff from being moved all the time. the guys at audi said they just need to take the seat panel off and spray it with something but that the airbags wont go off whilst the warning light is on..
  9. Re: Audi A3 airbag light
    #19
    Got the air bag light 'extinguished'! Put a new crash sensor on by the headlight, £61!
    The emissions system light is due to a faulty throttle sensor or something, build up of carbon in it, I'm giving it a good thrash round at the moment (within the legal speed limit obviously) to try and clear it out a bit!
  1. Airbag Light
    By Dude15 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-06-2008, 03:21 PM
  2. Audi A3 airbag light
    By gilly_15 in forum New Member Introductions
    Last Post: 12-06-2008, 07:28 PM
  3. a4 airbag light
    By fatfighter in forum Audi A4 - Archive Topics
    Last Post: 10-11-2007, 11:15 PM
  4. Audi A3 2001 Airbag Light... ??
    By craigbeal in forum Chat - Anything with wheels
    Last Post: 29-10-2007, 10:49 PM
  5. Airbag Light!!!!!!
    By diamond1 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-04-2007, 06:18 PM
