Thread: Passat Rear Number Plate
  1. Question Passat Rear Number Plate
    Dec 2006
    Can anyone tell me how to remove the rear number plate from a W reg (1999) Passat
  2. Passat rear number plate
    Nov 2006
    East Yorkshire
    The number plate is usually held on with a couple of screws. If not it could be stuck on?
  3. Angry
    Dec 2006
    Passman thanks for replying. Definetley not stuck. There are, what appear to be, two black slot head screws. However when you "attack" them with a screw driver they turn out to be made of softish plastic/rubber and they turn 90 degrees (both directions) and then the rubber gives way. i.e they are twisiting until they resist sufficient for the slot to give way.
    I wondered if they were a plug (to make removal difficult). otherwise maybe i should just keep at it with a screw driver and risk destroying the "screw".
    this is doing my alpha male self image no good whatsoever.
  4. force
    Dec 2006
    Sunny Shropshire
    I put my private plates on back in the summer on my 2002 estate and the "soft" plastic screws just broke off, i drilled the remains out and used screws with the covers on em
    Dec 2006
    Cheshire
    sorry.... cont..
    ....sheared off.
    any advice would be appreciated.
    thanks.
    Dec 2006
    Cheshire
    hi, sorry something went wrong with my message.
    can you tell me how you got the soft plastic screws out of the rear number plate? I have a similar problem on my Touran.
    Thanks,
  7. Force
    Dec 2006
    I forced the head of the screws and they sheared off. Pulled number plate off to reveal rust in the area that received the screws. i.e they were rusted in. Carefully drilled rest of screw out and fixed new screws. Could just stick it with silicon mastic I am told.
  1. VW Passat - number plate help!
    By jaycee621 in forum Chat - Completely Off Topic
    Last Post: 02-03-2008, 07:16 PM
  2. number plate legalities?
    By Eshrules in forum Chat - Completely Off Topic
    Last Post: 12-06-2007, 02:04 PM
  3. Number Plate Lights???
    By bogey888 in forum Audi A3 - Archive Topics
    Last Post: 02-02-2007, 02:04 AM
  4. Number plate light
    By shd01 in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2006, 10:43 AM
  5. Auto1 Award: The Passat is Europe’s Number One
    Last Post: 07-03-2006, 08:56 PM
