Thread: Transporter t5 brake warning light
Results 1 to 10 of 13
  1. Question Transporter t5 brake warning light
    Got problem with transporter T5 brake pad wear light staying on, switched pads even though plenty left on old ones and light still on, bypassed sender and still on anybody got any suggestions ? thanks
  2. Re: Transporter t5 brake warning light
    Hi You will probably find a break on one of the wires in the harness,you need to strip the insulation,you may do a heads and tails to see what side you do first.
  3. Re: Transporter t5 brake warning light
    Tried all those, been told it could be a problem with vacume pump, hard to believe as only done 30k any other suggestions thanks
  4. Re: Transporter t5 brake warning light
    Hi Cant understand how it has anything to do with the vacume pump,who told you that?
  5. Re: Transporter t5 brake warning light
    a so called mechanic,
    Ihave linked out sensor on pads and checked out leads with ohms meter
    all seem fine really doin my head in now
  6. Re: Transporter t5 brake warning light
    Have you checked the rear pads?
  7. Re: Transporter t5 brake warning light
    Loads of wear left on rear and there are no sensors on rear.
  8. Re: Transporter t5 brake warning light
    Yes there is rear right
  9. Re: Transporter t5 brake warning light
    sorry you where right , but to no avale i just whipped of the wheel and there is loads of meat on that one and bridging out the connectors did not work.
  10. Re: Transporter t5 brake warning light
    In that case there must be a fault with the instrument .you can recode it, and remove the ol brake pad control function
  1. Brake Warning Light On
    By vtskier in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2008, 09:27 AM
  2. Brake light warning
    By petros in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2008, 08:29 AM
  3. A3 Brake warning light
    By samz77 in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 11:47 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  5. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
