Thread: What the car says
  1. What the car says
    Mar 2008
    Hi All
    I am new to this so thanks in advance but my car has problems mentioned on another thread but after using a copy of VAG com 409.1 with a lead of ebay and this is the codes any help please
    VAG-COM Version: Release 409.1-US
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76
    Address 01: Engine
    Controller: 038 906 019 GQ
    Component: 1,9l R4 EDC G000AG 1524
    Coding: 00001
    Shop #: WSC 05314
    WVWZZZ3BZ3E014371 VWZ7Z0B5029020
    3 Faults Found:
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    17569 - Manifold Temp Sensor (G72): Open or Short to Plus
    P1161 - 35-00 - -
    17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
    P1156 - 35-00 - -
    Readiness: N/A
    Address 02: Auto Trans
    Controller: 3B0 927 156 S
    Component: AG5 01V 1.9l-PD RdW 1416
    Coding: 00103
    Shop #: WSC 05311
    1 Fault Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    Address 03: ABS Brakes
    Controller: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04257
    Shop #: WSC 05311
    No fault code found.
    Address 08: Auto HVAC
    Controller: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0005
    Coding: 17000
    Shop #: WSC 05311
    Skipping Address 15-Airbags
    Address 16: Steering wheel
    Controller: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 05314
    Address 17: Instruments
    Controller: 3B0 920 947 E
    Component: KOMBI+WEGFAHRSP VDO V08
    Coding: 21415
    Shop #: WSC 00000
    1 Fault Found:
    00476 - Control Module for Fuel Pump (J538)
    49-00 - No Communications
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    2 Faults Found:
    00463 - Control Module for Digital Sound Package (J525)
    Address 46: Central Conv.
    Controller: 1C0 959 799 B
    Component: 8Q Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    2 Faults Found:
    01134 - Alarm Horn (H12)
    37-10 - Faulty - Intermittent
    01135 - Interior Monitoring Sensors
    36-00 - Open Circuit
    Address 56: Radio
    Controller: 1J0 035 186 D
    Component: RADIO SON 0004
    Coding: 05403
    Shop #: WSC 05311
    1 Fault Found:
    00852 - Loudspeaker(s): Front
    36-10 - Open Circuit - Intermittent
    fuel costs suk
  2. Re: What the car says
    7 Post(s)
    You have got quite a few there and they may be historical.
    I would clear them down and see if any come back. Hopefully they won't.
    Post back when you have done so.
  3. Re: What the car says
    Mar 2008
    Sorry it took a while but the car behaved for a day after i wiped the codes but now its back with a vengeance
    Address 01: Engine
    Coding: 00001
    Shop #: WSC 05314
    1 Fault Found:
    P1556 - 35-00 - -
    Readiness: N/A
    Coding: 21415
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 00006
    Shop #: WSC 05314
    2 Faults Found:
    Coding: 00258
    Shop #: WSC 05311
    1 Fault Found:
    Address 56: Radio
    Coding: 05403
    Shop #: WSC 05311
    1 Fault Found:
    I left them all in as thy all could be interlinked or not
    fuel costs suk
