Thread: lights don't flash when locking
  1. lights don't flash when locking
    steviej Guest
    When I unlock my 02 Passat Estate the lights flash but they no longer flash when I lock the car.
    Any ideas?
    Bristol
    I have had the same problem with my 51 plate. It started after I had done an angel eye conversion to the front lights. I thought I had wored them wrong. A couple of weeks later it sorted itself out (saved me the cost of a tip to the dealers !). Have you found the cause of your problem ?
    Bristol
    I really should use Spell Check, when replying LOL
    Dec 2006
    Madrid, Spain
    Quote Originally Posted by steviej View Post
    Any ideas?
    That usually means that the microswitch inside the lock is wrong. Open all doors and check the lights under the door... probably one of them does not light-up. That light is connected directly to the open/closed switch inside the lock. If it is faulty, the cost is about 100€ (sorry for talking about euros...) or if you want, you can try to fix it unmounting and re-solding the small board inside the lock. This is usually the cause of many problems.
    Hope this helps!
    steviej Guest
    Still not working.
    All the under door lights are OK, doors and tailgate lock and unlock normally. One interior light is not working but surely it can't be that can it?
    Is there an alarm I coudl have turned off?
    Jun 2006
    I have a similar problem and think that this thread might help you:
    https://www.vwaudiforum.co.uk/forum/s...light=deadlock
    Dec 2006
    Durham, England
    Hi guys,
    Might be worth seeing if you can get the car plugged into a laptop with VAGCOM to see if any errors have been recorded by the measuring blocks. It may be as simple as resetting the software back to the factory default values as the angel eye conversion might be making things register differently to the sensors in the central locking.
    Hope this helps,
    David.
  1. Remote locking - no flash
    By A J Ball in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2007, 03:54 PM
  2. Central locking not locking
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2007, 03:11 PM
  3. Have you ever seen these lights?
    By jkruse123 in forum Chat - Completely Off Topic
    Last Post: 30-11-2006, 11:28 AM
  4. Passat Remote Locking/Locking
    By TallChris in forum Passat - Archive Topics
    Last Post: 22-11-2006, 01:14 PM
  5. interior lights and centeral locking
    By packdude in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-11-2006, 07:55 PM
