Thread: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
Results 1 to 8 of 8
  1. Question DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    HI!
    CAN ANYBODY HELP ME!
    I have a 1.6 1996 golf mk3 Magneti Marelli (AEE) engine, i think, got it 6 months ago. I took it to a garage spent over £600! full service, cam belt changed + other stuff got it back was ok and then it started idleing really bad.......
    It had a K&N filter, but it was filthy, and old, someone had not clicked the oil dipstick all the way in and OIL splashed over K&N air filter and went into the little air filter and down the breather pipe! I took off K&N filters and it started running bit better straight away, but then next day crap!
    I then took off beather housing and pipe and it was jam packed with old oil (mayo) and a bit of water, i cleaned it put it back on, sprayed out butterfly throttle housing with carb cleaner, got a original air filter housing from scrapy fitted it and put slick50 in the fuel!! OK!
    Started running bit better, the more i drove it but VERY LUMPY sounds like a tractor! Kept stalling when parking, full lock on power steering! Then tonite a parked it, went back to it and its DEAD! then engine turns but nothing happens, cant smell as any fuel either!!
    It has a hole in the centre box of exhust, front tyre leans in at the top, lock broke the other day! whats next!
    I bought a crap car, but WONT MAKE THE SAME MISTAKE AGAIN! Always go through the history well, you can learn alot about how the car was treated.. **** in this case!
    Did i need to do a throttle body alignment? follw link:
    http://wiki.ross-tech.com/index.php/...ment_%28TBA%29
    I thought VW was good, now i dont know ....
    Haynes manuals are **** nowadays too
    I
    AM
    GOING
    TO
    GO
    INSANE
    PLEASE
    HELP
    ME
  2. also HIGH FUEL consumption!
    Mar 2008
    It also had a vey HIGH FUEL consumption before it died....
  3. Re: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    The ignition coil had died, got new one, still running like a tractor!
    Will a throttle body alignment help it run better do you know?
    I intend to buy VAG-COM and a lead of ebay and do it myself..... Anybody done a THROTTLE BODY ALIGNMENT....
  4. Re: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    Fuel consumption is SO high and running like tractor, no power at low revs + VERY LUMPY!
    ALSO I noticed:
    WHen i tuch my HT ignition leads i get a little electric shock, this cant be right! Do i need new leads, will that help fuel consumption? It has recently been serviced, do they change leads on service?
    Hole in exhust, will this efect fuel consumption?
    Where can i get my throttle body alignment done?
  5. Re: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    I also took the shield off the ht leads while i was working on it, is that bad!
    Who killed kenny?
  6. Re: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    Also can i change the AIR/FUEL mixture using VAG-COM? I read somewhere you could! HERE http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
    I am going to keep writing on this forum, even if nobody answers! might help someone with same problem.. Good job i am stoned!
  7. Re: VAG-COM
    Mar 2008
    I used VAG-COM today and got the following fault message, anybody know what it means...
    VAG-COM Version: Release 409.1-US
    Chassis Type: 1H - VW G/J/V Mk3
    Scan: 01,02,03,08,15,25,56
    Address 01: Engine
    Controller: 032 906 030 N
    Component: MARELLI 1AV 2080
    1 Fault Found:
    00609 - Ignition Output 1
    31-10 - Open or Short to Ground - Intermittent
    Readiness: N/A
    Skipping Address 15-Airbags
    Address 25: Immobilizer
    Controller: 1H0 953 257 B
    Component: IMMO VWZ3Z0T1071455 V00
    Coding: 09600
    Shop #: WSC 00404
    No fault code found.
    Could this error be from the ignotion coil fault, Please help!
  8. Re: DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    Mar 2008
    Can a faulty Ignition coil damage my HT leads, distributor cap?
    My coil has recently been replaced, still running crap, 1 of the spark plugs is black with soot, the other are normal. WHY?
  1. 1996 transporter 2.4d strange engine tapping noise
    By fuzioneer in forum The Commercial Range
    Last Post: 10-04-2009, 06:23 PM
  2. 1996 Golf Mk3 Engine swap
    By Walczak in forum Golf MK3 - 1993 - 1999
    Last Post: 11-01-2008, 04:25 AM
  3. ABK Engine 2.0 Coupe April 1996 - Starting
    By JASPER6BEARS in forum 80 - 90
    Last Post: 25-06-2007, 11:03 PM
  4. MK3 Golf 1996 1.9TD CL - Pedal/Engine Knocking?
    By Mikejhan in forum Golf MK3 - 1993 - 1999
    Last Post: 18-06-2007, 12:34 PM
  5. Mk3 Golf GTi 16v 1996 (P)
    By jlx45v in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-11-2006, 10:16 PM
