Thread: Passat power loss
Results 1 to 10 of 19
  1. Question Passat power loss
    Mar 2008
    Hi sorry if this has been covered before but my passat 2002 tdi sport is being a big pain in the butt
    what happened was the wife let the fuel go in to the red then filled it up since then we have a intermittent problem with getting any speed out of the car
    when it has just started most times she runs great then all of a sudden I cant get her over 60 and if you put the foot down the revs go up the speed wont even going up hill she loses speed.
    I have replaced the fuel filter and put in some fuel additives that should help clear the injectors but with no luck.
    Still get times up to 16 miles before it goes limp other times its only a few miles and it makes no sense to me because its intermittent
    any help especially if it can save a big garage bill much appreciated
  2. Re: Passat power loss
    Mar 2008
    are you saying the revs go up but theres no increase in speed while driving?
  3. Re: Passat power loss
    Mar 2008
    yep thats what happens can floor the accelerator and no increase in power
    But have found that if we loose power pull over switch of the engine then switch it on again the engine runs like it should for a while
    fuel costs suk
  4. Re: Passat power loss
    Dec 2006
    Stoke/Congleton
    Sounds to me like it's going into limp mode.
    Find someone with vag-com in your local area, get fault codes read
    and this could shed some light on the problem.
    Could be leaking boost pressure or overboost....
  5. Re: Passat power loss
    Mar 2008
    OK gents this is the results from a VAG-COM on my car
    VAG-COM Version: Release 409.1-US
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76
    Address 01: Engine
    Controller: 038 906 019 GQ
    Component: 1,9l R4 EDC G000AG 1524
    Coding: 00001
    Shop #: WSC 05314
    WVWZZZ3BZ3E014371 VWZ7Z0B5029020
    3 Faults Found:
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    17569 - Manifold Temp Sensor (G72): Open or Short to Plus
    P1161 - 35-00 - -
    17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
    P1156 - 35-00 - -
    Readiness: N/A
    Address 02: Auto Trans
    Controller: 3B0 927 156 S
    Component: AG5 01V 1.9l-PD RdW 1416
    Coding: 00103
    Shop #: WSC 05311
    1 Fault Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    Address 03: ABS Brakes
    Controller: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04257
    Shop #: WSC 05311
    No fault code found.
    Address 08: Auto HVAC
    Controller: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0005
    Coding: 17000
    Shop #: WSC 05311
    Skipping Address 15-Airbags
    Address 16: Steering wheel
    Controller: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 05314
    Address 17: Instruments
    Controller: 3B0 920 947 E
    Component: KOMBI+WEGFAHRSP VDO V08
    Coding: 21415
    Shop #: WSC 00000
    1 Fault Found:
    00476 - Control Module for Fuel Pump (J538)
    49-00 - No Communications
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    2 Faults Found:
    00463 - Control Module for Digital Sound Package (J525)
    Address 46: Central Conv.
    Controller: 1C0 959 799 B
    Component: 8Q Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    2 Faults Found:
    01134 - Alarm Horn (H12)
    37-10 - Faulty - Intermittent
    01135 - Interior Monitoring Sensors
    36-00 - Open Circuit
    Address 56: Radio
    Controller: 1J0 035 186 D
    Component: RADIO SON 0004
    Coding: 05403
    Shop #: WSC 05311
    1 Fault Found:
    00852 - Loudspeaker(s): Front
    36-10 - Open Circuit - Intermittent
    Any ideas as its all greek to me
    fuel costs suk
  6. Re: Passat power loss
    Ireland
    Have the same fault on my A6 Gear box.
    1 Fault Found:
    This puts my gearbox into limp mode and i have to pull over and re start.
    Changed the MAP sensor, fuel filter air filter etc.
    Let me know if you get any results, ive been scouring the A6 forum looking for answers but none to date....
    Best of luck
  7. Re: Passat power loss
    Mar 2008
    Well at the moment the car is running great since I cleared all the fault codes yesterday but time will tell I will keep you posted
    fuel costs suk
  8. Re: Passat power loss
    Ireland
    It'd be nice if that worked for ya!
    Tried it on mine but to no avail
  9. Unhappy Re: Passat power loss
    Mar 2008
    Talk of the kiss of death the wife went out today and the same things happened and the new codes are as bellow
    Address 01: Engine
    Coding: 00001
    Shop #: WSC 05314
    1 Fault Found:
    P1556 - 35-00 - -
    Readiness: N/A
    Coding: 21415
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 00006
    Shop #: WSC 05314
    2 Faults Found:
    Coding: 00258
    Shop #: WSC 05311
    1 Fault Found:
    Address 56: Radio
    Coding: 05403
    Shop #: WSC 05311
    1 Fault Found:
    This is what i get now.
    I left all the error codes in case they are linked some way.
    fuel costs suk
  10. Re: Passat power loss
    Same thing happened to me yesterday! What is going on here!
    In the past I have had the same problem with my A4 jetta. It turned out to be a flakey MAF. I put a new one in and never had the problem again.
    Another friend of mine with an 02 golf experienced something similar and it turned out to be the accelerator sensor. In my experience, when it goes it doesn't start working again after shutting off the car and restarting it.
    Hope these suggestions help.
  1. Passat power loss
    By oxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2008, 06:22 PM
  2. Passat Power loss, not the maf
    By Andyrg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 11:51 PM
  3. passat power loss
    By ethers14 in forum New Member Introductions
    Last Post: 01-10-2007, 11:25 PM
  4. Passat Loss of power (no not the maf ?)
    By JayZee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 09:43 PM
  5. loss of power vw passat tdi
    By gerwyn42 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2007, 10:20 PM
