Thread: stuck window polo 1.4 2000
Results 1 to 9 of 9
  1. stuck window polo 1.4 2000
    Mar 2008
    Can anyone advise me as to what the fault on my wifes polo could be. The passenger side electric window just clicks and dont move,i have noticed when you click the window button the revs drop briefly,the window did go down and up once for the 1st time in ages yesterday,then did'nt work again. Any help and tips would be very welcome.
  2. Re: stuck window polo 1.4 2000
    Mar 2008
    you need to look into something called a regulator...This is was regulates the control of the window, new, they cost around £80. This is one of the common probs with the polo. Get VW to take a look at it.
  3. Re: stuck window polo 1.4 2000
    Mar 2008
    Thanks for your reply, i will look in to it as soon as i can,this might sound daft but is there a way of testing regulator before i spend any money buying parts?
  4. Re: stuck window polo 1.4 2000
    take your door card off and check in the bottom of the door for bits of broken plastic!
    the winows are held onto the regulator by plastic clips. these break and eventually you window will fall into the door completely.
    you cant buy just the clips, so have to buy the complete regulator. you can however, if slightly pikey like me fix the prob with self tapping screws!
    i did this on my old mk4 and the windows have been fine since (over 3 years)
  5. Re: stuck window polo 1.4 2000
    Mar 2008
    that sounds like a good plan...I know that mine was broken when i got the car (made the garage pay for it) and it costs about £80 for a new regulator...if you can fix the one you have, and it works, then thats the best way
  6. Re: stuck window polo 1.4 2000
    Jun 2008
    Durham, UK
    I'm having the exact same problem - I've got the door card off and yes there are bits of plastic in the bottom of my door. I'm guessing this is the regulator issue - the only problem I've got is that I'm loathed to buy a haynes for a car I haven't got. I've got the polo classic (2000) and haynes don't do a manual for this specific car.
    So I have 2 queries -
    Anyone know if anyone one does do a workshop manual for this model.
    And what does this regulator look like so I can either replace it or be a bit pikey and screw it back in place??
    Thanks!!
  7. Re: stuck window polo 1.4 2000
    the workshop manual for a seat ibiza mk2 will have the info you need as the polo classic (saloon and estate) are basically a rebadged ibiza.
    the regulator is the bit that bolts to the window and has the winding cables connected to it.
  8. Re: stuck window polo 1.4 2000
    Jun 2008
    Durham, UK
    Marvelous!!!
  9. Re: stuck window polo 1.4 2000
    Jun 2008
    Durham, UK
    Just found this elsewhere in the forum and had a read - doesn't apply exactly to the Polo but the theory is just the same.
    http://forums.vwvortex.com/zerothread?id=1015107
    Hope it helps anyone else that has the same problem!
  1. 99 Polo petrol cap stuck, central locking broke
    By vwhoch in forum Polo - Derby - Lupo - Fox
    Last Post: 24-08-2009, 01:07 AM
  2. 2000 polo elect window fault.
    By glitzy in forum Polo - Derby - Lupo - Fox
    Last Post: 14-02-2008, 08:17 PM
  3. 2000 Polo - x Reg - Help please?
    By mellowmunkee in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2008, 07:08 PM
  4. 2000 Polo GTi Oil
    By bryn_p in forum Polo - Derby - Lupo - Fox
    Last Post: 08-04-2007, 09:11 PM
  5. Bonnet catches stuck shut - Polo 2001
    By rgf1 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2006, 03:59 PM
