Thread: what is econ, how do you use it?
Results 1 to 10 of 11
  1. what is econ, how do you use it?
    Mar 2008
    I am just about to buy a 2005 passat 2.0 tdi dsg SE with aircon, when i test drove it the dealer said to me that it was ECON and it was better than aircon, I left the dealer a bit confused.
    Can someone tell me how the aircon works in a SE, I could not see an aircon button just the dials and an econ button...does the car even have aircon?
    Is the econ button to stop the using the air con pump/gas and use the external cold air..?
    If anyone can help i would appreciate it.
  2. Re: what is econ, how do you use it?
    Mar 2008
    Econ just turns off the chiller, so yes just uses the outside air. Bit confusing but I suppose it is more economical does defeat the object though.
  3. Re: what is econ, how do you use it?
    Mar 2008
    Thanks, the vw dealer told me that econ was better than air con but not as good as climate. . . I assumed he had got it wrong.
  4. Re: what is econ, how do you use it?
    Apr 2007
    France
    12 Post(s)
    Although it will use slightly more fuel, hence 'Econ' (and thus, VW suggest, not so good for the environment), using the aircon will clear your windows quicker and obviously keep the car cool in the summer. Also, I am led to believe that leaving the aircon turned off for prolonged periods doesn't do the seals etc. any good.
  5. Re: what is econ, how do you use it?
    I also find that if I don't use it much it tends to smell a bit when it's turned on again.
    Or perhaps it smells the same all the time but if it's used more then I just get used to it
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  6. Re: what is econ, how do you use it?
    Quote Originally Posted by csopho View Post
    Climate control is basically just a sophisticated version of air con, while the Econ option just switches either version back to a standard car heater system.
    Don't know what the dealer could have meant, but maybe he was trying to say that having the Econ option is better than having no option to switch off the air con/climate control at all.
    By the way, I think the SE's system is in effect more sophisticated than air con, but less sophisticated than climate control. I think (but may be wrong) that this is because in basic air con you just get a standard hot/cold heater-style control, whereas with the SE you can set the desired temperature on the dial. On the other hand, full climate control allows you to digitally set the desired temp. VW marketed this as 'Climatic' semi-automatic.
  7. Re: what is econ, how do you use it?
    Sep 2007
    South Manchester
    The system on my "S" version is Semi automatic.
    You can set the temp dial to the desired comfort & the system will try to maintain the temp that temp by some kind of control valve.
    The blower speeds & direction controls are manual.
    On a fully auto system these are controlled automatically or manually if
    desired by the use of actuators.
    Pressing the Econ button will disengage the clutch on the compressor so the air will not have the heat/moisture removed by the AC system. Although the system shuts down under 5c to avoid icing
    I had a lot of trouble on my SEAT Alhambra with the AC, I would rec that you leave it on. A guy on my old Seat forum posted info on his AC comapny & some FAQ's
    Gaz
    http://www.airconditioningforcars.co.uk/ACpage01.htm
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  8. Re: what is econ, how do you use it?
    Tyldesley, Manchester, UK
    Now I am no expert on the Passat let alone the B6, but my B5.5S (for Standard ) came with Climate which has ECON/AUTO button as standard.
    I would of thought the B6 SE had Climate as standard?
  9. Re: what is econ, how do you use it?
    Quote Originally Posted by MalcQV View Post
    As far as I know both the S and SE have the "Climatic" semi-automatic system, which I (tried to) explain above.
  10. Re: what is econ, how do you use it?
    Quote Originally Posted by Stuart W View Post
    Yep you did, just re-read it
  1. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  2. A6 Econ Light
    By SKIPPY75 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-10-2007, 07:35 PM
  3. Econ Light Staying on
    By Mark Ormiston in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-08-2007, 06:17 PM
  4. Econ mode will not turn off
    By AndyJ in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-07-2007, 07:50 PM
  5. Econ permanently on?
    By defero31 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2007, 12:51 PM
