Thread: Audi 80 2.0L ABK engine juddering/misfire
Page 7 of 13 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 129
  1. Re: Audi 80 2.0L ABK engine juddering/misfire
    #61
    Dec 2007
    Guess that's what I'll have to try now - just got an audi 80 that will have to last me several months (my trusted mechanic can't change the camchain on my saab till Feb :-( ) and the juddering was getting on my nerves. Got a fault code reader and 2x2 adapter and no fault codes at all. Just changed the dizzy cap, rotor arm and ignition leads (the car has had spark plugs a few K miles ago).
  2. Re: Audi 80 2.0L ABK engine juddering/misfire
    #62
    Dec 2007
    :-( Just took the relays out and opened them both (the smaller 30 and larger 363). No dry joints at all Now I'm running out of ideas!
    1998 S reg VW Golf S MK4 TDI 90 (1.9 66KW AGR) 130K miles
    1994 M reg audi 80 Sport SE (2.0 8V ABK) 111K miles
  3. Re: Audi 80 2.0L ABK engine juddering/misfire
    #63
    Hampshire
    Hi everyone, am new today in an effort to find out why my late Mreg Audi 80 2,0E is juddering - so good (in a funny way) to find out it's not just my garage thinking I'm a dippy female! Was over the moon reading Steve's solution....til I read the last post saying that didn't work. Oh well, at least I can check if a dry joint is my prob. Not that I can do it, but I know a man who can! haven't had a bill yet for the last 2 garage visits but they have done diag tests with no result, replaced idle control valve & rotor arm, checked electrics etc etc etc ad mauseam. I just want my lovely car to get back it's poke! I'll keep you posted if it finally solves the problem. Cheers guys
  4. Re: Audi 80 2.0L ABK engine juddering/misfire
    #64
    Hampshire
    By the way, it seems a lot of you have had the car die on you - I haven't had this (yet lol) but the prob is almost constant when around 3000 revs. Unfortunate since that's cruising revs. Drove back from Gatwick the other night in a howling rainstorm with it happening all the time - nasty! Doesn't seem to matter if it's wet or dry out. Anyway, I'll let you know if resoldering the joints works. If so, I'd like to buy SteveInDaBury a !
    And apols for all the typos in my previous post!!
  5. Re: Audi 80 2.0L ABK engine juddering/misfire
    #65
    Dec 2007
    Welcome to the forum, hope you'll get your audi sorted soon! Despite being an old scrapper the audi handles OK and is a surprisingly decent car! It even returns around 30mpg (2.0E sport SE = ABK 8V engine, manual transmission).
    Still no news here, couldn't be bothered with the one I'm driving, it still occasionally surges on tickover (actually the revvs drop and then go up to prevent stalling). Guess it may be an air leak somewhere, I'll need to spray some brake cleaner around the throttle body and see if the revvs go up a bit...
    Unless someone has a different idea???
  6. Re: Audi 80 2.0L ABK engine juddering/misfire
    #66
    May 2007
    Quote Originally Posted by Jillbaby View Post
    Good luck with the soldering, note that dry joints are not always obvious so if in doubt it doesn't hurt to resolder the joints anyway.
    I really wish I'd taken a before and after pic.
    drinks always welcome
  7. Re: Audi 80 2.0L ABK engine juddering/misfire
    #67
    Gwent
    If it's any help? Pics of what it should look like in this thread:
    https://www.vwaudiforum.co.uk/forum/s...?t=1787&page=2
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  8. Re: Audi 80 2.0L ABK engine juddering/misfire
    #68
    Hampshire
    Well sound the trumpets and give that man a knighthood!! After about 7 months, 3 trips to the garage and much swearing - I think it's fixed!! Had a mate look at those joints and indeed some were dry. About 10 minutes later, after a quick resoldering of all the joints guess what: the car ran like new and has done for about a week now with no sign of the old trouble returning. My baby's finally got its poke back! I can't believe that something so simple to fix (and even I could have done it, if I had a soldering iron) is not on the checklist with this kind of fault. It certainly should be now. SteveInDaBury, there's a beer waiting for you here in Hampshire - can't thank you enough mate! ). Listen everyone - if you've got this juddering problem, check those joints first and save yourself a lot of hassle and money at the garage. Mind you, I haven't yet had the bill for the last two trips before Christmas, maybe that's cos they knew they hadn't fixed it!
  9. Re: Audi 80 2.0L ABK engine juddering/misfire
    #69
    Hi folks,
    Another member of the 'juddering club' here !! Have just read with interest all your posts and am relieved to discover I am not alone !! I have a 1995 A6 Avant 2.0l ABK. Lovely car but for the juddering !
    Will spare you the details of what I have tried ( and spent ) so far as you have all previously covered it.
    Excitedly removed the relay panel under steering wheel only to find four relays in place precisely as depicted in the Haynes manual ( Body Electrical System 12.3 Page 12 Illustration 3.9b ). These are numbered left to right 213, 204, 229, 208 and labelled as follows
    213 = Relief Relay ?? No idea what it's for !! Audi Nr 443 951253J
    204 = Horn Relay
    229 = Intermittent Wiper Relay
    208 = Diesel / Jetronic ( I think pump ? )
    Also looked in engine compartment relay box and drivers side door sill area relays.
    Cannot find the ECU relay or any relay with 30 on it.
    Also the relief relay 213 seems to be better sealed than the others so cannot open it !!
    Would dearly appreciate any ideas !!
    Huge Thanks in advance to anyone who replies !!
    AM
  10. Re: Audi 80 2.0L ABK engine juddering/misfire
    #70
    PS I noticed that some of you guys have sourced secondhand MAF boxes. Would appreciate if anyone could direct me toward a source as I fear that could still be a contributing factor.
    Next step after (if) I can find the darn ECU relay !!
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. 99 Audi A4 Quattro, Misfire Cyl 3, Help!?!
    By wilvelas in forum Audi A4 - Archive Topics
    Last Post: 03-12-2007, 10:41 PM
  3. Engine Juddering / Too Hot
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2007, 02:09 PM
  4. Audi 80 Avant - Intermittant misfire ?
    By kbowern in forum 80 - 90
    Last Post: 23-05-2007, 01:50 PM
  5. VAG-COM Engine Fault 16684 - Misfire
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 30-01-2007, 09:56 AM
