Thread: hazard lights flashing !
Results 1 to 9 of 9
  1. hazard lights flashing !
    Sep 2007
    Hi , has any one had the problem of thier hazard lights start flashing for no reason ? Sometimes the car will be parked up alarm on , and i will get a call that my lights are flashing but no alarm , any ideas thanks ?
  2. Re: hazard lights flashing !
    Jul 2007
    Cheshire, or my A6
    Faulty hazard switches are not uncommon.
    Paul
  3. Re: hazard lights flashing !
    May 2007
    Hornchurch, Essex
    Quote Originally Posted by papalion View Post
    Does your alarm actually sound when set off? my alarm just flashes hazards with no horn at the mo as the alrm unit is cream crackered.
    AUDI A4 1.8T QUATTRO SPORTS : 2001 B6
  4. Re: hazard lights flashing !
    Sep 2007
    No , ive never heard it go off . ill have to try and set it off . How do you know yours is duff ?
  5. Re: hazard lights flashing !
    May 2007
    Hornchurch, Essex
    sit in the car and lock it via the remote central locking. wait a minute then move about, this will activate the alarm from the internal sensors, you'll see the hazards go and you should hear it. mine has no sound and a diagnostics plug in confirmed problems with it. also when you lock the car your red l.e.d on the drivers door will flash, if it stays solid red lit up that also means the alarm is not functioning properly. try all that and see what happens.
  6. Re: hazard lights flashing !
    Sep 2007
    Did that today and my alarm went off but was only an internal siren , like a high pitched buzzer . Is that right , that would not attract attention ?
  7. Re: hazard lights flashing !
    May 2007
    Hornchurch, Essex
    dont sound right to me. what about the red l.e.d on the drivers door? did it stay solid lit up red for about 30 seconds before flashing again?
  8. Re: hazard lights flashing !
    Sep 2007
    The lights start to flash as soon as i arm the alarm .
  9. Re: hazard lights flashing !
    May 2008
    hi, I have the same problems my hazards flash but no siren, the door led stays solid for 30 seconds which indicates a fault with the alarm system, does anyone know what could be wrong and is it expensive ..also is it a dealer only fix....
    Thanks in advance
  1. hazard lights
    By simo911 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 09-04-2009, 08:43 PM
  2. Hazard lights coming on when indicating
    By Dex2034 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2008, 02:26 PM
  3. side hazard lights
    By squinty in forum Audi A3 - Archive Topics
    Last Post: 14-05-2007, 06:24 PM
  4. Hazard Lights/Indicator problems
    By Ricky_TT in forum Archive posts
    Last Post: 14-05-2007, 01:25 PM
  5. Audi A3 R Reg - Oil & Temp lights keep flashing
    By Shahid in forum Audi A3 - Archive Topics
    Last Post: 31-01-2007, 07:15 PM
