Thread: VAGOM =vs= KWP2000
  1. VAGOM =vs= KWP2000
    Crosby, Liverpool
    Hi folks,Iv got a KWP2000 usb lead, however it doesnt seem to want to play ball with vagcom.Iv got the right version (409) I can test the LED's and the test comes back fine and dandy.But when I test the USB port it just gives the usual Port:OK Interface:Not detected. However if tested without the usb plugged in, it says 'No Ross-Tech compatable interface detected' so in some wierd and twisted way it must be detecting the cable somewere along the lines!Any Ideas chaps?Or should I bight the bullet and buy a proper ross tech cable? If it helps im using vista on the latop thats trying to connect to the car
    Audi A4 B5 1.6 -1998 <~~~ GONE
    Audi A4 B7 2.0 - 2005<~~~ GONE
    Audi A4 B5 1.8 T 1996 <~~~Here for now
  2. Re: VAGOM =vs= KWP2000
    May 2007
    Leeds
    Are you sure you have not bought an actual "KWP2000" for reading and writing the ecu?
    If you have even the shareware vag-com will not work
    Look at the sponsors section. There is a current group buy on the cables!
    Paul
  3. Re: VAGOM =vs= KWP2000
    Crosby, Liverpool
    Yer mine is a proper kwp2000 cable,got the software etc with it.the software that came with it works ok on other cars,but just doesnt work with vag com.Ill get a cable off ebay or something.Or is it better to get one from ross tech folk?
  4. Re: VAGOM =vs= KWP2000
    May 2007
    Leeds
    Well not quite propper, a clone of a propper one maybe
    You need to look at a cable designed for vag-com
    Paul
  5. Re: VAGOM =vs= KWP2000
    General advice is to steer clear of KWP2000, these are for flashing ecus mainly, not really for diagnostic, certainly not the likes of those available on eBay with a complete lack of support.
    for pocket money, there is no such cable that I can think of that is all singing, all dancing, compatible with all vehicles.
    for VAG, you'll either need a generic 'dumb' 3rd party cable, to run on 409, or you can purchase a newer style cable from rosstech directly.
  1. kwp2000 and tuning files is it safe
    By zorgman in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2008, 03:51 PM
  2. SEAT and vagom info
    By cbrpaul in forum Archive posts
    Last Post: 25-10-2007, 02:57 PM
