Thread: where would I find a standard CD Changer fitted
Results 1 to 10 of 15
  1. where would I find a standard CD Changer fitted
    Hyde
    Where should it be fitted to ? is it in the boot or inside the car some where.
    Thx
    130 TDI - 2003
  2. Re: where would I find a standard CD Changer fitted
    my standard cd changer is a single front load unit located above the tape deck. dont suppose this helps tho
    VW Golf Mk4 1.8T
  3. Re: where would I find a standard CD Changer fitted
    I found mine in the boot in the compartment where the fire extinguisher + first aid box should have been!hope this helps
  4. Re: where would I find a standard CD Changer fitted
    Hyde
    I dunno it may do... I think mine has the 6 pack in, but im not sure you see.. when I have one disc in, and press say button No 2, it just says no disc inserted, having read the hand book, it may be that there is a changer fitted but I aint loaded it up yet (cos I cant find it), the dash cd player has a single slot load, but I'm unsure on how to get any other discs into the player ??
    Thx
  5. Re: where would I find a standard CD Changer fitted
    N/A
    ~That sounds like the same player fitted in mine!
    Its a single slot front with the 6 changer built into the back of it .
    If you press the load button the cd player will automatically select the first empty compartment, the light near the player slot then flashes and you the insert the cd ! You can load/eject a cd to numbered position you want by pressing the number you want then load/eject !
  6. Re: where would I find a standard CD Changer fitted
    Hyde
    Thx gman3.0 I'll give it a go tomorrow, it does have the select button, and when you press it the CD change light comes on for a second
  7. Re: where would I find a standard CD Changer fitted
    if it has a 'select' button it cant have the numbers 1-6 also. its either a single cd player or a 6 disk multi.
    if it has a light for the 'cd changer', it means that you can connect an external multichanger and pressing 'select' engages it.
    if it has an 'eject' button and a 'load' button along with the numbers 1-6, the headunit itself is a multichanger. you press the button named load then after 3-5 seconds you insert a disk
    you saying that it has a 'select' button leads me to believe that it is a single head unit with the option to connect a multichanger/ipod
    VW Golf Mk4 1.8T
  8. Re: where would I find a standard CD Changer fitted
    Hyde
    well youve just described it very well so I recon its a single unit with the addon if needed, I've had a look in the boot space, just a first aid kit, nothing more, so I guess its a single shot for now..
    Thx for the help and advice guys, Im just reading up on de-locking now
  9. Re: where would I find a standard CD Changer fitted
    ive got a link fot the auction that i used 2 delock mine. 2 replacement barels and end caps that you need to get sprayed. there good value at 12 or so quid. easy to do although you will most probably need torx drivers. theres a lil cap on the end of the door when its open. you remove that gromit then 'loosen' the fixing. DO NOT UNSCREW ALL OF THE WAY!!! or the fixing may fall to the bottom of the door, meaning you need to remove the door card and all kindsa crap!!! it shudnt need to be removed all of the way to remove the barel anyways. once loosened, simply pull the door handle outwards and waggle the barrel out!!! i only needed to do this at one side as it only had 1 barrel!
    http://cgi.ebay.co.uk/VW-Golf-Bora-D...QQcmdZViewItem
    VW Golf Mk4 1.8T
  10. Re: where would I find a standard CD Changer fitted
    Hyde
    Thanks Very much Shleng
    Just found this tut on it, looks quite straight forward..
    http://www.billswebspace.com/VWMKIVDelockMod.htm
  1. standard euipment
    By FIBAMAN in forum Jetta MK3 - 2005 - 2013
    Last Post: 20-04-2008, 06:21 AM
  2. Does anyone know the standard RPMs?
    By Kookoo in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2008, 02:58 AM
  3. Standard Headunit
    By cuprachris in forum Leon
    Last Post: 02-01-2008, 10:56 AM
  4. are the wheels standard OEM?
    By RichRoberts in forum Audi A4 - Archive Topics
    Last Post: 01-09-2007, 01:36 PM
  5. What is standard bhp on a mk3 golf 2.0 16v gti???
    By ash_00_2004 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-06-2007, 05:07 PM
