Thread: flashing exclamation mark on dash
  1. flashing exclamation mark on dash
    Nov 2006
    I have recently noticed that when I am driving, a circle with an exclamation mark inside it flashes on and off constantly. The car seems to drive fine and there doesn't SEEM to be any problems, and I was just wondering what this sign meant and if I have a problem? Thanks
    nik
    Canada
    The exclamation symbol is a warning light for your braking system, I would get it checked immediatly. It warns for worn pads, low brake fluid level etc. So don't ignore it you could end up with no brakes if you have a leak.
    The most important thing before moving is stopping!!!!
    I don't now what exactly flashing means for your model but it allways good to treat anything with brakes as very urgent.
    Rob
    Nov 2006
    sorted mate! was my brake fluid. but i now have a problem as i obviously have a leak. where do i look? there are no obvious signs on my drive for evidence of leakage.
    Canada
    It may not be a leak, it could be just wear on the pads. you need to check your brake pad wear to see how much is left and look for any leaks in the process. most likely places for leaks are hoses to the brake calipers/drums or wheel cylniders.
    Get a Haynes Manual or better still take it to a mechanic and get him to have a look, as I said before don't take chances it your neck!!!
    Rob
  1. flashing symbols?
    By dieselal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-05-2007, 08:11 PM
  2. Newbie please help abs and exclamation mark light
    By 20vt1 in forum Archive posts
    Last Post: 07-03-2007, 01:01 AM
  3. Newbie ABS and exclamation mark light HELP PLEASE!!!
    By 20vt1 in forum Passat - Archive Topics
    Last Post: 05-03-2007, 10:01 AM
  4. passat flashing dash lights
    By minty0_10 in forum Passat - Archive Topics
    Last Post: 25-11-2006, 11:18 PM
  5. Indicator not flashing ?
    By nigelainge in forum A8 - S8 - V8
    Last Post: 28-06-2006, 10:21 AM
