Thread: Are there any good VW independants in Merseyside?
  1. Are there any good VW independants in Merseyside?
    LWW Guest
    Can anyone point me in the direction of a VAG independant in Merseyside or even the North West? Just had a VW quote for a Cambelt change on a V6TDI at £630 !!!
    Oct 2005
    Chester, U.K
    I use Central VW in Ellesmere Port, phone number 0151 355 1246 ask for Simon or Pete, good lads, labout charge is £38 p hr plus VAT I'm afraid, tell them Gary the taxi driver sent you.
    Aug 2006
    LWW. There is a guy in Crosby who is an independent VW garage. Unfortunately I don't have the name of the garage. However, he is located behind P&A Audio which are on Liverpool Road, not too far from Merchant Taylors Girls school.
    I've only ever heard good reports about him so it may be worth your while trying him out.
    I hope this helps.
    KD
    Nov 2006
    I've used central VW in Ellesmere port, what i'd call a proper garage.
  5. Re: Are there any good VW independants in Merseyside?
    Oct 2012
    Southport UK
    Hiya, the VW independent garage behind P+A Audio in Crosby Liverpool is called D+A O'Shea.
  6. Re: Are there any good VW independants in Merseyside?
    LWW Guest
    Thanks everyone for the recommendations. I've used Central VW in Ellesmere Port a number of times for the bigger jobs that I couldn't / wouldn't do through the dealer. They did my cambelt change, some clutch work & a lowering on an eibach kit. Not used them for a while as just had the one car for the last couple of years and Ellesmere Port is a long way out for me. Having said that the garage is right next to the railway station so you can drop off then head to Liverpool or Chester if you want. Always been very reasonable cost wise given the work they've done. No hesitation in recommending them.
  1. Rules for the "Dealer & Independants" section
    By stuart in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 21-12-2009, 02:10 PM
  2. Good morning to you all!
    By bigfella_v5 in forum New Member Introductions
    Last Post: 13-06-2007, 06:05 PM
  3. Hello. Its good to be here
    By RIZWAN180 in forum New Member Introductions
    Last Post: 05-04-2007, 06:19 PM
  4. Independants.Rip off merchants.
    By VAG fan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-08-2006, 06:20 AM
