Thread: How to remove Touran battery ?
  1. How to remove Touran battery ?
    Hi there,
    Having recently come into possession of a Touran I'ev found that it hasn't been driven in a month and as such the battery has gone flat and now it won't start.
    Is it ok to charge the battery using a standard charger ? manual says not but not sure if this is just the usual manufacturers trick to get you to one of their service centers.
    How do you remove the battery if I want to replace it ? I've undone the terminal brackets but the thing won't budge.
    Cheers,
    Mully
  2. Re: How to remove Touran battery ?
    looked in my handbook ,yes can use charger but not into cig lighter sockets says nothing about removing ,is it just stuck if removed fixings,sorry not much help ,on my 3rd touran so must enjoy
  3. Re: How to remove Touran battery ?
    No worries just got it done there, here's a quick run down.
    The entire battery has a plastic casing around it, remove the top of this.
    Remove the terminal clamps.
    What is left runs around the outside of the battery like an exterior wall, it is divided and clipped together halfway back.
    Remove the front section- beware it will take a bit of brute force but essentially rocking it back and forwardwill get the two side clips free, then pulling towards you and up will remove the clips at the front.
    Next you will see a bolt on the LHS this is clamped over the bottom lip of the battery and holds it in place very sturdily. I think it is a 13 mm socket you need to remove this, I suggest unscrewing by hand once you have loosened to prevent the clamp and screw falling.
    After this jiggle the battery a bit to the left then pull towards you and it should come out.
    Then you are free to charge \ replace whatever !
  4. Re: How to remove Touran battery ?
    thanks for info will print and keep ,thanks
  5. Re: How to remove Touran battery ?
    Jun 2008
    Easy when you know how. Saved me a lot of aggravation and cursing and swearing. Thanks.
  6. Re: How to remove Touran battery ?
    Nov 2012
    A, A
    That was really useful thanks.
    Btw, the battery supplied by halfords was wrong. They supplied a hb110 which was listed but I changed it for a shorter hcb096 that was an exact fit.
  1. Replies: 4
    Last Post: 08-10-2015, 02:54 AM
  2. Touran battery drain
    By julesprice in forum Touran - Sharan - Caravelle
    Last Post: 24-08-2009, 09:33 PM
  3. How to remove the audio (radio/CD) kit?
    By rjs993 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-01-2008, 04:41 PM
  4. Touran - remove driver door panel
    By rmcleod1576 in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2007, 03:37 PM
  5. A3 Can't remove oil filter !!!
    By byrlord in forum Audi A3 - Archive Topics
    Last Post: 19-07-2007, 05:47 PM
