Thread: What oil should I use - 04 Passat 130 1.9 TDi
Results 1 to 10 of 20
  1. What oil should I use - 04 Passat 130 1.9 TDi
    Got a Passat yesterday on a 04 plate (estate - 5 speed manual gearbox).
    It's a 1.9 TDi 130 bhp (96 kw).
    The manual says to use High-lubricity multigrade oil, either;
    VW 506 01
    or
    VW 505 01
    dependant on "Vehicles with LongLife service" or Vehicles without LongLife" service.
    I have two questions;
    1) How do I determine what engine type I have - with or without longLife.
    2) I live a long way from a VW main dealer - what oil could I safely use if I brought it from a regular car parts shop (this is dependant on answer 1).
    I need to top up, so I don't want to drive until I know what oil I can use.
    Thanks for any help you can give.
    Gilly.
  2. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2007
    Liverpool
    If you go for a long life service schegule then use VW 507.00 spec oil these tend to be 5w30.
    I personally change my oil every 6,000 miles and use a VW505.00 5w40.
    Because your engine is a PD (Pump Duse) then you must use the correct oil to avoid engine damage.
    1998 Audi A4 2.8 V6 quattro
  3. Re: What oil should I use - 04 Passat 130 1.9 TDi
    Letterkenny, Co. Donegal, Ireland
    Hi, i also have a quick question about oil grades - i need to top up and looked at my manual for the correct grades i needed, My A4 1.9 TDi is on a 9000 mile service schedule, and the manual says i need oil which has BOTH VW 500 and VW505. However, when trying to get oil in garages etc, i can only find oil with either 500 or 505, not both.
    If i go for one of these oils, is there potentially any damage that can be caused, or will it be fine to just use either?
    Any help much appreciated.
  4. Re: What oil should I use - 04 Passat 130 1.9 TDi
    If ur on the longlife service then castrol edge does the job only thing is its £40 for 4ltrs if ur on the 10,000 interval gsf do fuchs pd oil for £19.99 for 4 ltrs plus vat if its a 130bhp its more than likely a awx engine code its on a sticker in ur boot by the spare wheel. Ed
    Ed
  5. Re: What oil should I use - 04 Passat 130 1.9 TDi
    Aug 2007
    someone posted a very useful list of the various manufacturers 505.01 oils on here a few months back and that was copied from a 2003 post I think. I lost my copy and have been unsuccessful in searching for the original posts. Maybe someone still has a copy ?
  6. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2007
    Liverpool
    https://www.vwaudiforum.co.uk/forum/f...splay.php?f=94
    Everything you need should be here
  7. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2016
    Zagreb, Croatia
    Hi there, my first post here and right away I need your help. I have a 2003. Passat 1.9 tdi pd 96kw, and at the moment I'm using total quartz 9000 5w40 full synthetic, for year and a half now. Engine is running smooth, oil changes every 6000 miles, and is barely losing any oil between change intervals. Since It came to my attention that it's not a 505.01 standard oil (which i'm definitely getting soon for my next scheduled service) I'm wondering could it damage the engine in any way?
    Thank you in advance, bb
  8. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2012
    Everywhere
    308 Post(s)
    Ooops , I know of a main dealer doing exactly the same for years supplying a non PD oil , it resulted in cam wear thus an injector missfire .
    5W30 507.00 LongLife is a higher quality oil than 5W40 505.01 .
  9. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2016
    Zagreb, Croatia
    Quote Originally Posted by Gazwould View Post
    Ugh..well, that sounds depressing. Thanks for your reply mate.
    Probably going castrol edge or anything premium with a 505.01 mark next, don't quite see the purpose of using longlife oils with my mileage and change intervals, with my PD oldie.
  10. Re: What oil should I use - 04 Passat 130 1.9 TDi
    May 2012
    Everywhere
    308 Post(s)
    It's the oils quality mate , 507.00 is superior to 505.01 in terms of wear etc .
