Thread: How to remove Golf MkV sidelight bulb ?
  1. How to remove Golf MkV sidelight bulb ?
    Oct 2006
    Stansted, Essex
    I need to replace the front sidelight bulb on an 04 plate GT tdi. However there is limited room to get a hand in and I am uncertain whether the bulb just pulls out or does it need twisting first?? I don't want to break the light unit!! But it seems very tight. I presume it is possible without removing the complete light unit first?
    They are a push fit on MK IV, not sure about a MK V. Space is a bit tight but try and give it a "wiggle" side to side and pull at the same time.
    Hope this helps.
    Regards Boardboy.
  3. Smile
    Oct 2006
    Stansted, Essex
    Having managed to remove the off side sidelight bulb by pulling it out it soon became apparent that the nearside would be more difficult in view of the lack of space to insert ones hand. However by using the offside bulb holder as a pattern I bent a piece of metal coat hanger to the right shape which I then used to slide over the nearside bulb holder and gently pulled it free. Easy!!! Might be of help to someone in the future! ?
    Glad you got it sorted and I like the use of the coat hangar
    Regards Boardboy
  5. I know How to remove Golf MkV sidelight bulb
    Nov 2006
    you need pincer pliers to depress two tiny clips on the top and bottom flat parts of the retainer, then gve it a gentle pull and voela! It will practically fall into your hands.
  1. Replacing sidelight bulb on A6
    By PapaG in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-05-2010, 04:08 PM
  2. How to Remove ECU from Golf MK5 2005?
    By rj4eva in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2007, 09:23 PM
  3. A4 Sidelight Bulb
    By shabs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2007, 06:22 PM
  4. A4 rear sidelight bulb replacement
    By Ian McIntosh in forum Audi A4 - Archive Topics
    Last Post: 21-11-2006, 08:09 PM
  5. Sidelight Bulb
    By Paul JP in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-04-2006, 09:51 PM
