Thread: AAT/AEL New crank or re-grind???
Results 11 to 20 of 30
  1. Re: AAT/AEL New crank or re-grind???
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Quote Originally Posted by philbarber View Post
    I'm very willing to help anyone considering an AAT/AEL rebuild. I will freely give the benefit of my experience and contacts list. Just call me on the above number or via this site.
    Phil Barber
    hi I'm very interested in timing on these engines, we have an aat and an ael, the aat runs very well, timing since the belt changes according to vagcom is dead on!, it does splutter and tick over a little rough sometimes, but the ael is the main concern, again belt's changed toothed crank sprocket and bolt and tensioner changed we can get it to start and run, when u set the timing on vagcom to ael 1000rpm it wont re start unless pump timing is moved, set it to ael 1200rpm and it will start but smoke.
    what timing marks are you using? i have checked the marks on the ael 3 times, the cam is locked in place the bottom pulley appears to have a mark to line up with the lower timing cover, and there is a mark on the flywheel which lines up with the hole on the gearbox.
    can you tell me where I've gone wrong?
    we are in Dudley west mids.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: AAT/AEL New crank or re-grind???
    129 Post(s)
    1972 Post(s)
    There is a zero on the flywheel, don't trust the front pulley mark as it may have moved due to de-bonding of the rubber damping ring.
  3. Re: AAT/AEL New crank or re-grind???
    May 2007
    surrey / yorkshire
    Exellent thread!
    I'm thinking about rebuilding my AEL in the futere as it has 206k on it now and is starting to sound tractor like.
    Still it's running lovely and starts fine but i'd like to improve it as it's a fantastic engine.
    Cheers for the useful info.
    (you may get some questions from me soon)
    Regards
    Gareth
    Audi A4 B5 1.8T
  4. Re: AAT/AEL New crank or re-grind???
    8 Post(s)
    Looks like I need my AEL rebuilt, I've been having starting problems since we changed the timing belt and has been smoking + high rocker cover presure since day 1.
    We took the head off today hoping to find that the piston rings were sized due to overheating, not the case unfortunatly.
    We found piston no.1 must have hit a valve when the cambelt snapped and the head was changed by a previous owner, though the edge of the piston was damadged to and this has left a nice score down the bore.
    I'm going to have to get the bottom end rebuitl, any recomendations for people in the midlands and a guess at cost?
    Paul
  5. Re: AAT/AEL New crank or re-grind???
    129 Post(s)
    1972 Post(s)
    A genuine exchange Audi bottom end is just under £1700.
  6. Re: AAT/AEL New crank or re-grind???
    8 Post(s)
    I'm not paying any where near that! I won't be going to Audi
    I'll get some prices on monday.
  7. Re: AAT/AEL New crank or re-grind???
    #17
    Dec 2007
    44 Post(s)
    You can order them from GSF or Euro under the part number 77 244 610 for 0.25 u/s.
    do you have the part number for them std size?
  8. Re: AAT/AEL New crank or re-grind???
    #18
    Gwent
    std size Audi parts are: 034 105 701 - lower shell
    034 105 701B - upper shell
    I believe these are made by Kolben Schmidt, and the upper shell has its alloy coating applied by a 'sputtering' process - which gives better adherence to the steel backing than the traditional method.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  9. Re: AAT/AEL New crank or re-grind???
    #19
    129 Post(s)
    1972 Post(s)
    Standard size shells from KS are 77 244 600 and I would try not to do a regrind if possible, especially no more than 0.25 or you go through the surface treatment and the crank then wears very quickly. The correct part number for the lower shell is 034 105 701 007 @ £5.03 each and the upper shell is 034 105 701 B 40Z @ £12.23 each so £86.15 for genuine bearings. The set from KS is much cheaper and still features the Sputter coated upper shell.
  10. Re: AAT/AEL New crank or re-grind???
    #20
    Dec 2007
    44 Post(s)
    are these avaliable from Euro car parts? or is there somewhere else you recomend? the crank doesn't need a regrind, but new shells will be fitted, also can these blocks be sleved? or is it a rebore and + sized pistons??
  1. 02 a4 3.0l crank no start
    By matt9129 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2007, 11:23 PM
  2. VR5 Crank Sensor...
    By suisideg60 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2007, 11:14 AM
  3. Audi 80 steering grind and judder
    By STiVO in forum 80 - 90
    Last Post: 03-11-2007, 10:35 PM
  4. 98 Passat won't crank
    By bpiach in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-06-2007, 01:17 PM
  5. Crank Sensor?
    By my1stGTi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-04-2007, 08:58 PM
