Thread: wiper motor relay
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. wiper motor relay
    The wipers stopped working the other week, and have been trying to find the problem. Its not a fuse, and I cannot hear a click of the relay. But, the trouble is that I cannot find out which relay relates to the wipers.
    Please help!
  2. Re: wiper motor relay
    Hi The intermitent wiper relay is in position 3 (197),but if the wipers do not work on full speed then i is either the switch or the wiper motor,which is at fault
  3. Re: wiper motor relay
    Thanks for that.Have just got one and fitted it, to no avail. The wipers don't work at all, regardless of the speed setting at the stalk.
    mmmm any ideas chaps?
  4. Re: wiper motor relay
    129 Post(s)
    1972 Post(s)
    One of what fitted, motor, stalk or relay? It is usually the motor.
  5. Re: wiper motor relay
    It is a new relay that I fitted.
    I think you may be right about the motor since the wipers ceased working on the day after I had washed the car and the air temp went below 0 degrees an hour or so after I finished.
  6. Re: wiper motor relay
    Feb 2007
    UK (London)
    What year is your car?
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  7. Re: wiper motor relay
    Its a 1999 T reg
  8. Re: wiper motor relay
    Feb 2007
    UK (London)
    This is your problem and what you will need to do to fix it if not you will need to buy a nwe one.
    Fixing WipersDe2006
    Writeup for fixing slow wipers, specifically for face lift A4's. Text appears above the reference pics, unless otherwise noted. Standard DIY disclaimer applies.
    Tools / Supplies:
    8mm socket or nut driver
    10mm socket
    13mm socket
    2" socket extension
    Small flathead screw driver
    Medium flathead screw driver
    #2 Philips head screw driver
    Soft wire brush (I used a brass bristled brush)
    Grease
    Time: @ 1 hour
    Difficulty: 2/10
    Begin by stalling your wipers in the verticle position. Remove the battery/rear firewall cover. Using a small flathead screwdriver, pop off the wiper arm spline covers.
    Using a 13mm socket, remove the retaining nut that holds each wiper arm to the spline.
    Once the nuts are removed, carefully rock the wiper arm using an up and down motion as you pull up on the arm at the mounting point. Do not rotate the arms in a wiping motion or you could strip the splines. When you have both arms off, remove the plastic cowl by undoing the four quarter-turn plastic philips screws. There's also a metal clip at the end on the drivers side (visible as the rusty square below and right from the wiper arm in the above pics).
    With the cowl removed, the entire wiper assembly should be visible. The assembly is held in with 3 10mm bolts and an electrical harness. The three bolts are circled in red, and the harness is circled in green. Undo the 3 bolts. Unless you have infant hands, don't try to undo the harness just yet. There's at least 6" of wiring behind it that makes undoing it easier once the whole assembly is out of the cavity (via a later step).
    In order to pull the assembly from the cavity, you'll need to make some room, because the wiper motor that's mounted on the back of the assembly is about the size of a can of Campbell's soup. To make room, remove the engine ECU cover, which is held in place with a few 8mm screws. At this point, You should have something like this. (obligatory beer shot)
    Now you should have room to work the assembly out of there. It might try to catch on the mounting points at the ends, so be persistant, and use different angles. I took mine out by freeing the pass side of the assembly first. Be mindfull of the exposed ECU and components. Don't knock them around. Now with the assembly out of the cavity, it should be easy to reach the electrical harness. Press the release button on the harness and disconnect it.
    Take the assembly over to your workbench for the troubleshooting (don't mind my mess). Here it is, in all of it's glory. The motor is mounted in the middle. As it turns, it pushes/pulls on the linkage arms, which then push or pull on levers that are mounted to the splines. (NOTE: I think I have the direction of rotation of the motor in the middle going the wrong way. It should turn clockwise.)
    At this point, I noticed some crud on my splines, so I took the opportunity to clean them using some WD-40 and a brass bristle wire brush. Remove the rubber caps from the splines and start cleaning. Don't damage the splines while scrubbing them. They're pretty delicate.
    To troubleshoot where my wipers were binding, I disconnected the linkage arms from the center motor. I used a flathead screwdriver to lever the plastic ends out of the ball joint. Both linkages are mounted to the same balljoint. During dissassembly, the passenger side linkage is removed first, then the driver's side.
    Once the linkages are free from the motor, the splines "should" be free to rotate in their housings. I was able to actuate the passenger side just fine with no effort, however, my driver's side wouldn't budge. It was ceased pretty good. I even pounded on the lever arm with a BFH to try to free up the spline shaft, but that didn't do any good either. That wiper motor has to be pretty powerful to be able to move that thing as slowly as it did.
    Now that I've identified where my binding was coming from, I also wanted to test the wiper motor to make sure it wasn't damaged or burned-out from making that ceased spline move. Plug it back into the electrical harness and make sure the assembly is free from obstructions. Turn on the wipers. Mine worked like a champ, so I proceded to clean the ceased driver's side spline shaft.
    The spline shaft is held in place by a washer and a circlip at the base of the splines. You can barely make them out in this pic. I used a small flathead screwdriver to remove the circlip. If you choose to take this approach, try not to stab yourself in the hand when it slips.
    When you have the circlip and washer removed from the spline shaft, the only thing that's holding it in is friction. I used PB Blaster and a hammer to pound the spline out the back of the housing. Again, don't damage the splines. Threat the 13mm wiper arm mounting bolt back on, if your aim is that bad. Here you can see my spline shaft halfway out, and you start to see the corrosion that was going on inside. Also, the removed circlip retainer and washer are visible on the work surface.
    All's that's left is to clean the shaft and the inside of the housing, followed by a generous lubing with some grease. Reassemble everything and reinstall it all in reverse order.
    *NOTE: when working with any part of your car's electrical system, it would probably be a good idea to disconnect the battery. I did not do this, and got lucky. Fate was with me. Have your radio code handy before you disconnect the battery.
  9. Re: wiper motor relay
    Thanks for an awesome post.
    Just what I needed to get the wipers sorted. Will have to get the part tomorrow and crack on with it.
  10. Question Re: wiper motor relay
    Mar 2008
    Hello everyone-
    I am in the US. I have a 2003 A4 Avant 1.8T.
    My wiper system looks just like the one in Docurley's awesome post.
    However, my reasoning for repair is my wipers are stuck in the halfway position. I tried to move them, and NOW they're stuck perfectly verticle.
    The wipers work on all setting but end up in the wrong place.
    This all happened when really wet snow was piled on my windshield and the wipers were on before I could remove the snow.
    So- is there any way to RESET what the splines are thinking? I tried to just put the wipers in the correct position but they just jam at the bottom of the windshield.
    ANY help is appreciated.
    JOHN in Park City Utah
  1. Rear wiper motor
    By Harry in forum Audi A3 - Archive Topics
    Last Post: 15-02-2008, 02:33 PM
  2. Audi 80 location of blower motor relay pack
    By barryw in forum 80 - 90
    Last Post: 29-11-2007, 07:25 PM
  3. Intermittent Wiper Relay - HELP!
    By Steve P in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2007, 01:00 PM
  4. wiper relay
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 11:21 PM
