Thread: A6 1.9 TDi coolant temperature sensor
  1. A6 1.9 TDi coolant temperature sensor
    Dec 2007
    My 2002 A6 temperature guage is fluctuating between 60 to 90 and I think is is the coolant sensor. Can anyone help on locating it?
  2. Re: A6 1.9 TDi coolant temperature sensor
    need your engine code
  3. Re: A6 1.9 TDi coolant temperature sensor
    Dec 2007
    Awx
  4. Re: A6 1.9 TDi coolant temperature sensor
    Hi the temp sensor you will find at the rear of the cylinder head,(drivers side) below the boost hose.It has 4 wires running to it.
  5. Re: A6 1.9 TDi coolant temperature sensor
    Dec 2007
    I can see it.
    To get the connector and clip off you need to be a contortionist with very thin arms.
  6. Re: A6 1.9 TDi coolant temperature sensor
    Aug 2007
    Wicklow
    Anyone got a guide to changing this? Would a faulty one of these cause the engine to over-rev, especially when starting? My guage in the car sometimes reads 90, sometimes sits at around 70, sometimes at 0, which can change at anytime even during driving.
    Thanks.
  7. Re: A6 1.9 TDi coolant temperature sensor
    May 2007
    This sensor mucking around can cause the idle to be unstable. It's cheap to change.
    Different versions are different colours, so difficult to fit the wrong part.
  1. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  2. Coolant temperature below 90
    By paul.decowski in forum Audi A4 - Archive Topics
    Last Post: 15-01-2008, 01:45 PM
  3. Low engine coolant temperature, which coolant to use
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 11:35 AM
  4. Coolant temperature sensor reading too high
    By vlad21 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 01:32 PM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
